Midgetgem1973
Message 2 of 12
A light at the end of a tunnel
Just seen a guy working on the cabinet that provides my street, I double checked that it was no.28 he said yes, I asked when is it going live, he said he didn't know but it shouldn't be too long now as he has just turned it on, all we have to wait for now is BT, so hopefully not too long now. 😃
So what do BT do now it's switched on and how long will it be before I can place an order?
11 REPLIES 11
Midgetgem1973
Message 1 of 12
Re: FTTC or not?
Jac_95 Can I ask how do you find out about which cabinets are still being installed and commissioned to the ones that are ready, as I would like to find out about the cabinets in my area please, postcode is BB8 8BN I'm on cabinet 28
Thank you
Midgetgem1973
Message 3 of 12
Re: A light at the end of a tunnel
Anyone know how long it takes to commision the new fibre cabinet?
gg30340
Message 4 of 12
There is no set time scale. It can take months depending on a variety of things all coming together.
See this link from forum member pippincp
http://beusergroup.co.uk/technotes/index.php?title=Diary_of_an_FTTC_Install
imjolly
Message 5 of 12
If you stand beside the new caninet can you hear the fans. If so then activation close if nothing then not ready yet
Midgetgem1973
Message 6 of 12
So when the guy said he had turn the cabinet on, doesn't mean the fans will be on?
I will have walk to it tomorrow and have a listen
imjolly
Message 7 of 12
It may be he was connecting the power but in my own case there was weeks between power installed and activation. If fans working them my cab was live in less than a week
Midgetgem1973
Message 8 of 12
Ok thank you, I will keep checking day by day on bt and the wholesale checker
jac_95
Guru
Guru
Message 9 of 12
Re: FTTC or not?
Hi Midgetgem1973,
Not sure why you wanted a list of FTTC cabinets for your area but here you are.
Below are the FTTC cabinets in the BB8 postcode area (be that already installed & FTTC available and those that are still either being installed/commissioned or planned to be installed)
  PCP (Cabinet) Exchange FTTC Status
BB89NF 1 COLNE  Still being Installed/Commsioned
BB88DW 2 COLNE  Available
BB89QW 3 COLNE  Available
BB89RH 4 COLNE  Available
BB89LU 5 COLNE  Still being Installed/Commsioned
BB80NW 6 COLNE  Available
BB80PH 7 COLNE  Available
BB80NZ 8 COLNE  Available
BB87PE 9 COLNE  Available
BB87BN 11 COLNE  Available
BB87HE 12 COLNE  Available
BB88QU 13 COLNE  Available
BB80RB 15 COLNE  Available
BB88JN 16 COLNE  Available
BB89EJ 17 COLNE  Available
BB89BA 18 COLNE  Still being Installed/Commsioned
BB89SJ 19 COLNE  Still being Installed/Commsioned
BB88AD 20 COLNE  Available
BB87HL 21 COLNE  Available
BB80AZ 22 COLNE  Available
BB88SA 23 COLNE  Still being Installed/Commsioned
BB87JZ 25 COLNE  Still being Installed/Commsioned
BB80NQ 26 COLNE  Available
BB80PJ 27 COLNE  Available
BB88BJ 28 COLNE  Still being Installed/Commsioned
BB80LQ 29 COLNE  Available
BB88BF 31 COLNE  Available
BB80LH 32 COLNE  Still being Installed/Commsioned
BB80EJ 33 COLNE  Still being Installed/Commsioned
BB80LG 34 COLNE  Still being Installed/Commsioned
*** Number of postcodes analysed: 754 | Out of : 754 | Number of hits : 30 ***
It can take some time for a FTTC DSLAM cabinet to be fully commissioned and set as ready to accept FTTC orders.
As you can see from the above, your cabinet 28 is still in the process of being commissioned/installed.
As recommended by others your best to keep checking the BT Wholesale database at http://dslchecker.bt.com/adsl
Hopefully it won't be long till you can order FTTC fibre broadband such as BT Infinity.
ray_dorset
Distinguished Guru
Message 10 of 12
Re: FTTC or not?
How did you generate the list?
If not, I'll try again 🙂
