husk1
Message 1 of 9
ADSL Faceplate & Internal Wiring
Hi, can someone confirm if this will work or not?
I have 2 pair CW1308 cable running from the master socket with the second extension socket in the living room, where the router is.
I want to fit an ADSL faceplate, remove the bell wire and use the spare 4th wire and connect them both to terminals A and B, leaving terminals 2 and 5 connected as usual for the telephone.
I would then bypass the first extension and terminate A and B on terminals 2 and 5 on the socket in the living room.
8 REPLIES 8
imjolly
Message 2 of 9
Re: ADSL Faceplate & Internal Wiring
that if I understand you will create star wiring and is more likely to cause a problem with your connection than help it
husk1
Message 3 of 9
I don't know what star wiring is, sorry.
I want to replicate what is going on in this video, but terminating in a standard extension faceplate.
https://youtu.be/oGDAAcpqm9Y
imjolly
Message 4 of 9
where are you fitting the filtered faceplate - to the master socket?  Are you going to use a MK3 openreach socket?
if you connect a second socket to terminals A&B so even if you use the test socket on master then second socket remains live then you have created star wiring which is normal detrimental to your broadband connection
husk1
Message 5 of 9
Still not quite following you sorry,
The plan was to connect the filtering ADSL faceplate to the master socket and leave it completely unused, then send the unfiltered broadband to one socket in the lounge via A & B (no voice connection) and leave the other extension sockets purely for voice.
So you're saying that would create interference..
imjolly
Message 6 of 9
By connecting to terminals A&B on the master and running a cable to a new socket you are creating star wiring. The correct wiring is when you use the test socket and all other sockets are 'dead' but in your scenario the extension socket would still be live
husk1
Message 7 of 9
There seems to be a difference between the MK3 faceplate and the one I'm thinking of using.
The MK3 has the A & B terminals on the main socket and therefore looks like it can't be cut off when the extensions are plugged in:
The one I'm looking at has the A & B inline with the other terminals so I don't think both sockets could be live I used that..
What do you reckon?
imjolly
Message 8 of 9
The terminals you have circled on the MK3 will give you an unfiltered socket just the same as terminal A&B on the filtered socket you are thinking of using
but I cannot see what you are going to achieve by doing that. It would be easier just connecting a modem cable rj11 to the filtered socket and gunning to where you intend to sit the router
husk1
Message 9 of 9
Well it would use the existing hidden cable, I've got nowhere to hide cable from the master socket.
I really just wanted to replicate the work in the video because I thought it was a tidy solution.
Thanks anyway.
