Message 1 of 3
ADSL Filter issues with broadband
Hello all
Keep having a repeated issue with the ADSL filter that is currently installed within my home. Whenever someone calls my house's landline (I.e. incoming call to the house landline), the router goes from the static blue colour state as it usually is to show its in full working order and connected to the internet as normal to flashing purple, then orange and back to solid blue, a process of which repeats for the entire duration of the phone call being taken on the landline. The current hub we've got is the BT Smart Hub 2 if that helps.
Is there any form of a quick fix for this issue? Would a secondary master socket installation be required to eradicate the problem and if so would BT engineers do this for me?
Would appreciate any help on this topic as it has been ongoing intermittently for a number of months if not, to be honest, years now.
Thanks.
2 REPLIES 2
Message 2 of 3
Re: ADSL Filter issues with broadband
@J_Fish
What does your master phone socket look like?
Message 3 of 3
Do you have an extension socket in your home with a phone connected but without a filter?  Have you replaced your current filter as they do not last forever
have you tried using test socket?
