bjosh
Message 1 of 4
ADSL Set up
Just a quick one
I have standard ADSL connection, using the smart hub. But I’ve just bought the Netgear XR500. Is my best option to buy an Openreach modem now?
Thank you
3 REPLIES 3
licquorice
Message 2 of 4
Re: ADSL Set up
Well you will need a modem of some sort, that device is just a router.
bjosh
Message 3 of 4
Re: ADSL Set up
Do you have any recommendations or shall I just get then Openreach one
licquorice
Message 4 of 4
Re: ADSL Set up
Up to you really. Openreach modems are only available via ebay etc at varying prices, Amazon are currently selling the D-Link DSL -320B for £9.99
Edit:  If you are likely to be upgrading to VDSL at any point, then get an ADSL/VDSL modem. The Openreach Huawei HG612 modem does both.
