I have had perfect ADSL at my address for years. Usually get sub 10ms ping and 17mb download 1mb up.
Recenlty I have been suffering 300-400 ping late into the evening, 11pm onwards. Download speed also then fluctuates and is no longer consistant at 17mb. Upload becomes barely useable and reports at 0.1 on speed tests. I thought it was a crackling line problem which I called BT after doing the 17070 test and heard crackling, bt engineer came replaced some cables down the road, crackling gone. But 11pm and later and suddenly ping shoots up to 300-400ms. This is noticible in an online game as ping is displayed constantly, and it then becomes unplayable along with browsing and other apps noticibly slower. If i dont reboot the router the ping returns to normal by the next morning. If i reboot it sometimes ping goes back to normal, sometimes it doesnt and stays bad for a day or so.
I have a pretty refined network, netgear DGN3500 used soley as a modem for adsl2+ whcih has been solid for years, with wifi switched off, pluged into a couple of netgear gigabit switches (gs108 & gs110tp), rj45 cable round the house, and also a netgear Nighthawk R700 setup as an access point purely for wifi. When the connection goes bad, low ping lower speed, it affects anything plugged into a router, a switch or on wifi so its definitely the adsl not the network problem. The bt engineer kindly gave me his phone number but he says he has fixed the phone line ran tests its fine, and I have repeated 17070 quiet line test and no more crackling, he doesnt know what to do next.
Ive kept a brief log of the connection info from when I first noticed the problem. This is info cut out of the 192.168.0.1 netgear info page.
all day bad ping and LOW 10mb speed
ADSL Link Downstream Upstream
Connection Speed 11026 kbps 674 kbps
Line Attenuation 16.7 db 8.6 db
Noise Margin 14.0 db 13.5 db
softreboot router 17mb seems ok
Connection Speed 17397 kbps 1057 kbps
Line Attenuation 16.6 db 8.5 db
Noise Margin 2.9 db 5.7 db
couple days later seems ok
Connection Speed 14328 kbps 1167 kbps
Line Attenuation 16.3 db 8.2 db
Noise Margin 7.0 db 6.4 db
after bt man been OK
Connection Speed 14328 kbps 1159 kbps
Line Attenuation 13.3 db 6.8 db
Noise Margin 10.1 db 6.8 db
21/6/16 good speed good ping
Connection Speed 20120 kbps 1135 kbps
Line Attenuation 13.4 db 6.8 db
Noise Margin 2.9 db 6.7 db
22/6/16 1130pm bad ping and speeed
Noise Margin 2.8 db 6.7 db
Also I have ran the ADSL checker as described in other posts , see below
Telephone Number 01895xxxxxx on Exchange RUISLIP is served by Cabinet 37
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
HighLowHighLow
Featured Products
WBC FTTP Availability Date
Left in Jumper
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
VDSL Range A (Clean) | 64.2 | 49.3 | 16 | 10.3 | -- | Available | -- | -- |
VDSL Range B (Impacted) | 49.4 | 30 | 12.4 | 5.7 | -- | Available | -- | -- |
FTTP on Demand | 330 | 30 | -- | Available | -- | -- | ||
WBC ADSL 2+ | Up to 17.5 | -- | 16 to 19 | Available | -- | -- | ||
WBC ADSL 2+ Annex M | Up to 17.5 | Up to 1.5 | 16 to 19 | Available | -- | -- | ||
ADSL Max | Up to 7.5 | -- | 7 to 8 | Available | -- | -- | ||
WBC Fixed Rate | 2 | -- | -- | Available | -- | -- | ||
VDSL Multicast | -- | -- | -- | Available | -- | -- | ||
ADSL Multicast | -- | -- | -- | Available | -- | -- |
and the bt wholesale test further diagnostics, which showed a 398 ping on the page before this further test
1. Best Effort Test: -provides background information.
Download Speed | |
14.68 Mbps |
0 Mbps | 21 Mbps Max Achievable Speed |
Download speed For your connection, the acceptable range of speeds IP Profile for your line is - 17.75 Mbps |
2. Upstream Test: -provides background information.
Upload Speed | |
0.44 Mbps |
0 Mbps | 0.83 Mbps Max Achievable Speed |
Upload speed Additional Information: Upstream Rate IP profile on your line is - 0.83 Mbps |
Im at a loss, as the connection is perfect all day usually, but now its 11pm its unusable. Any ideas? Or do i need to get fibre to make this go away?
Thanks in advance for any help from any one
your noise margin is very low at 2.8db have you checked how low it does drop say around 11pm?
Hi, yes so last night when the ping was 300-400 at about 1130pm the noise margin was as follows
this time its 8pm and the problems are here, high latency and poor download speed, slow browsing generaly. Noise margin is wayup. Quiet line test is quiet. Any one have any ideas?
Connection Speed 9368 kbps 291 kbps
Line Attenuation 13.6 db 6.9 db
Noise Margin 16.8 db 24.5 db
With your speed dropping that much and very high noise margin has your router been in dropping connection or have you been manually resetting trying to improve connection or a combination of both?
The router drops the connection, reconnects itself and is then at the high noise margin /bad connection stage. On various occasions I have spotted this be it 1 day later, or 1 hour later, and tried the reboot which usualy starts off connected at a perfect 20mbp /3db noise margin but shortly reverts back to 9mb or 3mb with high noise margin. So a combination
