Message 1 of 10
ADSL keep dropping
Hello guys
here is my story...
Since last week, my Internet connection has kept dropping.I contacted BT online help 3 times.On first two occasion I was told that there was a problem with the line after online chat guy did some test while I was waiting.They both raised a fault later I received a couple of calls from ,BT I was told the fault was fixed.They suggested to me to use main socket if it still keeps dropping.Unfortunately it still keeps dropping.I used the main socket ,changed the filter but it is still same.I did a quite line test and I can hear some background noise.
After my last contact with BT online help guy I received a text message from BT which telling me that the broadband line was resetted to stabilise my connection and asking me to keep router on for next 4 days...
My event log is full of
 03:01:40,18 May.	 PPP IPCP Receive Configuration ACK
  03:01:40,18 May.	 PPP IPCP Send Configuration Request
  03:01:40,18 May.	 PPP IPCP Receive Configuration Reject
  03:01:40,18 May.	 PPP IPCP Receive Configuration NAK
  03:01:40,18 May.	 PPP IPCP Send Configuration ACK
  03:01:40,18 May.	 PPP IPCP Receive Configuration Request
  03:01:40,18 May.	 PPP CHAP receive success: authentication ok
  03:01:39,18 May.	 PPP CHAP Receive Challenge
  03:01:39,18 May.	 PPP LCP Receive Configuration ACK
  03:01:39,18 May.	 PPP LCP Send Configuration Request
  03:01:39,18 May.	 PPP LCP Receive Configuration Reject
  03:01:39,18 May.	 PPP LCP Send Configuration ACK
  03:01:39,18 May.	 PPP LCP Receive Configuration Request
  03:01:36,18 May.	 PPP LCP Send Configuration Request
  03:01:33,18 May.	 PPP LCP Send Configuration Request
  03:01:30,18 May.	 PPP LCP Send Configuration Request
  03:01:27,18 May.	 PPP LCP Send Configuration Request
  03:01:24,18 May.	 PPP LCP Send Configuration Request
  03:01:21,18 May.	 PPP LCP Send Configuration Request
  03:01:18,18 May.	 PPP LCP Send Configuration Request
  03:01:15,18 May.	 PPP LCP Send Configuration Request
  03:01:12,18 May.	 PPP LCP Send Configuration Request
 it was a lot worse in the beginning; it was dropping in every 10-20 minutes now it is slightly better.
Many thanks
Post code ME20
Tel 01622 71****
9 REPLIES 9
Message 2 of 10
Re: ADSL keep dropping
Hi Welcome to the forums
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
also post your full hub stats details shown in this link http://www.btinternet.com/~cbeddoe/others/adslstats.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket   Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
Message 3 of 10
ADSL Line Status
Connection information
Line state:	 Connected
Connection time:	 0 day, 00:09:30
Downstream:	 3,821 Kbps
Upstream:	 1,136 Kbps
  ADSL settings
VPI/VCI:	 0/38
Type:	 PPPoA
Modulation:	 G.992.5 Annex A
Latency type:	 Interleaved
Noise margin (Down/Up):	 11.1 dB / 8.0 dB
Line attenuation (Down/Up):	 27.0 dB / 15.8 dB
Output power (Down/Up):	 0.0 dBm / 12.6 dBm
FEC Events (Down/Up):	 628 / 0
CRC Events (Down/Up):	 7 / 0
Loss of Framing (Local/Remote):	 0 / 0
Loss of Signal (Local/Remote):	 0 / 0
Loss of Power (Local/Remote):	 0 / 0
Loss of Link (Remote):	 0
HEC Errors (Down/Up):	 792 / 0
Error Seconds (Local/Remote):	 0 / 0
1. Best Effort Test:  -provides background information.
Download  Speed
10.76 Mbps
0 Mbps	21 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 10.76 Mbps
 For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
 IP Profile for your line is - 11.39 Mbps
2. Upstream Test:  -provides background information.
Upload Speed
0.92 Mbps
0 Mbps	0.83 Mbps
Upload speed achieved during the test was - 0.92Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.83 Mbps
I have not tried the test socket,I tried only main socket.I will try the test socket this evening.
I can hear some noise ,similiar to crakings when I try a quiet line test.
Thanks for all help...
Message 4 of 10
hi the noise needs solving first you need to contact BT faults on 151 and report the noise once that is fixed your broadband should improve do not mention broadband when you report the noise
Message 5 of 10
your hub stats and speed test results are not the same were they taken at different times
Message 6 of 10
FAQ
Download  Speed
10.68 Mbps
0 Mbps	21 Mbps
 Download speedachieved during the test was - 10.68 Mbps
 IP Profile for your line is - 11.31 Mbps
Upload Speed
1.17 Mbps
0 Mbps	0.83 Mbps
Upload speed achieved during the test was - 1.17Mbps
ADSL Line Status
Connection time:	 0 day, 02:09:47
Downstream:	 12,816 Kbps
Upstream:	 1,265 Kbps
  ADSL settings
VPI/VCI:	 0/38
Type:	 PPPoA
Noise margin (Down/Up):	 9.4 dB / 5.8 dB
Line attenuation (Down/Up):	 26.5 dB / 15.8 dB
FEC Events (Down/Up):	 18024 / 0
CRC Events (Down/Up):	 34 / 0
HEC Errors (Down/Up):	 1332 / 0
Message 7 of 10
those stats look remarkably different you look as if you have internal wiring problems have you removed the bell wire from terminal 3 of every socket this link explains more http://www.filesaveas.com/jarviser/bellwirenutshell.html
also do you have a sky box connected to a phone socket if so has it got a filter fitted to it
Message 8 of 10
also has the line noise been solved yet
Message 9 of 10
I tried the actual test socket,it is still the same, it keeps dropping...
I called 151 to raise a fault on the line.The guy on the phone thinks tha it might be happening because of my faulty equipment and asked me to use another telephone to check the noise. I need to find another phone to test it.I know it will be the same but ... anyway.
Last stats I attached may be misleading .I must tell the truth I used wireless connection to test btspeedtest. I am attaching the LAN cable results now
ADSL Line Status
Connection time:	 0 day, 00:04:44
Downstream:	 12,989 Kbps
Upstream:	 1,276 Kbps
  ADSL settings
VPI/VCI:	 0/38
Type:	 PPPoA
Noise margin (Down/Up):	 9.4 dB / 5.9 dB
Line attenuation (Down/Up):	 26.5 dB / 15.7 dB
FEC Events (Down/Up):	 704 / 0
CRC Events (Down/Up):	 2 / 0
HEC Errors (Down/Up):	 117 / 0
FAQ
Download  Speed
9.98 Mbps
0 Mbps	21 Mbps
 Download speedachieved during the test was - 9.98 Mbps
 IP Profile for your line is - 11.46 Mbps
Upload Speed
1.13 Mbps
0 Mbps	0.83 Mbps
Upload speed achieved during the test was - 1.13Mbps
 I do not know what else I can do.It is very annoying
Message 10 of 10
if the noise is still there at the test socket with the another phone then you need an engineers visit
