Message 1 of 3
ADSL or ADSL2 on a long line?
i have BT business boadband (office unlimited ADSL2 Next Gen (up to 20 Mb)). Historically i have had poor broadband hence swapping to business to try and improve matters. i have now ditched the home hub and gone to a 7800N which has made a big difference. although over Christmas the flashing lights played havoc with the broadband and now i have a high SNR margin and interleaving..
However, my main question is will it be worth me pushing for ADSL2 given my line (stats from DSL stats below). currently my router will only connect with G.DMT so i am assuming i can only get ADSL? Will ADSL2 or indeed 2+ improve speed/stability on a long line with attenuation around 62 dB?
thanks everyone
DSLAM/MSAN type:                       IFTN:0x71c8 / v0x71c8
Modem/router firmware:            AnnexA version - A2pB025f.d22k
DSL mode:                          G
Status:                 Showtime
Uptime:                               3 days 15 hours 12 min 13 sec
Resyncs:                              1 (since 16 Jan 2015 09:24:44)
        Downstream      Upstream
Line attenuation (dB):    62.0                        31.5
Signal attenuation (dB):                Not monitored
Connection speed (kbps):            2944                       448
SNR margin (dB):              9.7                          9.0
Power (dBm):                    17.8                        12.6
Interleave depth:            16                           4
INP:                       0.65                        1.88
RSCorr/RS (%):                  0.0225                   0.0051
RSUnCorr/RS (%):            0.0093                   0.0000
ES/hour:                              0                              0
adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 8000
Max:    Upstream rate = 688 Kbps, Downstream rate = 3264 Kbps
Channel:        INTR, Upstream rate = 448 Kbps, Downstream rate = 2944 Kbps
Link Power State:       L0
Mode:                   G.DMT
TPS-TC:                 ATM Mode
Trellis:                ON
Line Status:            No Defect
Training Status:        Showtime
                Down            Up
SNR (dB):        9.6             9.0
Attn(dB):        62.0            31.5
Pwr(dBm):        17.8            12.6
                        G.dmt framing
K:              93(0)           15
R:              8               16
S:              2               8
😧              16              4
                        Counters
SF:             18470539                18470803
SFErr:          4432            697
RS:             627998338               157001825
RSCorr:         141398          8020
RSUnCorr:       58116           0
HEC:            3611            586
OCD:            78              8
LCD:            0               2
Total Cells:    2179945133              0
Data Cells:     84244409                0
Drop Cells:     37
Bit Errors:     0               0
ES:             2322            0
SES:            49              0
UAS:            98              98
AS:             314005
INP:            0.65            1.88
PER:            1.75            1.75
delay:          8.00            8.00
OR:             32.00           32.00
Bitswap:        28562           750
Total time = 1 days 19 hours 20 min 38 sec
FEC:            213384          0
CRC:            5918            0
ES:             2322            0
SES:            49              0
UAS:            98              98
LOS:            1               0
LOF:            9               0
Latest 15 minutes time = 5 min 38 sec
FEC:            1740            0
CRC:            36              0
ES:             9               0
SES:            0               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
Previous 15 minutes time = 15 min 0 sec
FEC:            29484           0
CRC:            440             0
ES:             75              0
SES:            1               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
Latest 1 day time = 19 hours 20 min 38 sec
FEC:            57861           0
CRC:            1256            0
ES:             426             0
SES:            9               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
Previous 1 day time = 24 hours 0 sec
FEC:            16164           0
CRC:            422             0
ES:             228             0
SES:            2               0
UAS:            0               0
LOS:            0               0
LOF:            0               0
Since Link time = 3 days 15 hours 13 min 23 sec
FEC:            141398          8020
CRC:            4432            697
ES:             1803            0
SES:            28              0
UAS:            0               0
LOS:            0               0
LOF:            0               0
2 REPLIES 2
Keith_Beddoe
Message 2 of 3
Re: ADSL or ADSL2 on a long line?
Welcome to the BT Residential Customers forum
As you are a business user, please could you may be better posting on the  BT Business forum at http://business.forums.bt.com/
PS   With that amount of line loss, there would be no advantage in moving to ADSL2 or ADSL2+.
Estimation of your maximum rate adaptive adsl speed
Downstream
Attenuation
dB Approx
Line Length
km
dslMAX (20CN) kbps IP Profile kbps
BT 21CN WBC
& adsl2+
adsl2+ (LLU) kbps Throughput kbps
Message 3 of 3
oops thanks!!
