Message 11 of 48
Re: ADSL2+ Upgrade of Audlem Exchange (WMADM) very very disappointing
correct how ever BT now advertise download speed not connection speed as they did before that is the reason for the change
tractorman
Message 12 of 48
Hi
Info I posted is by using the BT filtered faceplate, if I take this off and connect via a normal filter to the test socket the results are the same, slight loss of line sync speed at 568K vs 576K but nothing really diffferent.
Non of this really explains why I have been getting 1mb for past 2 years and now after the upgarde I'm on less than half that amount. I doubt whether it is anything to do with my internal wiring / setup as that has not changed, the only thing that has changed is the exchange upgrade.
Message 13 of 48
the problem at present is the higher noise margin at 10.8 instead of 6db.  you need to stay connected 24/7 for 3+ days to show a stable conenction then contact the mods to get noise margin rset to 6 which should give the speed increase you are looking for
contact mods
can take up to 3 working days for mods to contact you - maybe slightly longer at present due to a backlog
but need 3 days stable connection first
tractorman
Message 14 of 48
Thanks, connection has been stable for past 10-12 days untill I manually reset last night to try and improve things, I'll contact them and see what they say.
Message 15 of 48
you really need to be able to show the 3+ days connection before mods will reset your noise margin
KevG123
Message 16 of 48
"if your attenuation is still 74db as in a previous post then ads2/2+ will never give you 16mb even 1.6mb would be really good"
I would kill for 1.6MbSmiley LOL
Message 17 of 48
with 74db attenuation you probably would need to before you got 1.6mbSmiley Wink
KevG123
Message 18 of 48
I know...Smiley Very Happy
I'll let you know how it goes
Those nice mod folks are letting me have ago - should be enabled by tomorrow night
Message 19 of 48
good  post details when you can
tractorman
Message 20 of 48
Not sure if Mods have reset the line yet but it reset itself about 3.5 hours ago and now the noise margin is close to 6dB, however my sync speed with the exchange is still only 568K, and IP profile is still at 500K again less than half of what I was getting before the upgrade. Interestingly I'm getting a much higher upload than download on the same line??? Stats below:-
Line state:Connected
Connection time:0 days, 03:36:19
Downstream:568.9 Kbps
Upstream:626.8 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.3 dB / 5.7 dB
Line attenuation (Down/Up):65.1 dB / 39.8 dB
Output power (Down/Up):16.8 dBm / 12.6 dBm
FEC Events (Down/Up):173216 / 959
CRC Events (Down/Up):0 / 81
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):0 / 156
Error Seconds (Local/Remote):1723 / 373
