tractorman
Message 31 of 48
Re: ADSL2+ Upgrade of Audlem Exchange (WMADM) very very disappointing
I understand that the stats show 992.3 Annex A ie just adsl2, but one thing that has changed since the upgrade is my up speed, this is now significantly higher than it has ever been, never used to get more than 425K sync and best ever actual up has been 390K in last two years, now its at 628K sync with actual around 550K. Does this not imply that line is actually using adsl2+ ?
Message 32 of 48
no the up speed on adsl2/2+ is the same but with modulation of 992.3 you are currently on adsl2 but if line quality improves it is an automatic change to adsl2+.  this would not increase your connection speed
Message 33 of 48
just a matter of waiting for the mods to get involved with the problem now
KevG123
Message 34 of 48
Sorry, not trying to hijack the thread, but thought worth sharing this
I contacted the mods to ask for their assistance in getting me on ADSL2+ as my exchange has JUST been upgraded
They emailed me last thurs to say they have put an order in due for next Friday - and to let them know how it goes
Which is excellent  as I'm very pleased they are giving me the opportunity to try  - considering my long line.
Message 35 of 48
be interesting to see your stats after the change to 21CN
tractorman
Message 36 of 48
Thanks Kev, worth knowing.
My line has held up now for one of my three days with the noise margin varying between 5.0dB overnight and 6.3dB, so hopefully when the mods take a look I'll get a higher IP and sync. Also found out about the Billion 7800N router today, may be worth a try if all else fails as then I can tweak my own noise margin, but I'll see what the mods can do first rather than shellig out £120 for it.
Message 37 of 48
you can get a netgear dg834 V4 and above with custom firmware and tweak the noise margin - far cheaper at well known auction site
KevG123
Message 38 of 48
Will definately post up my before and after stats
And if necessary, I have mobile broadband back up !Smiley LOL
Message 39 of 48
hope it does not come to thatSmiley Very Happy
tractorman
Message 40 of 48
Success! After 2days and 16 hours of stable operation around the 4.5-6dB noise margin the HH has resynced at 2.085MB with an IP profile of 1.88Mb, fastest I've ever had in last 8 years!!! Great job, just hope it all holds up now. Stats below, thanks for all of your help.
Connection Information
Line state:Connected
Connection time:0 days, 00:58:34
Downstream:2.085 Mbps
Upstream:547.6 Kbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.3 Annex A
Latency type:Interleaved
Noise margin (Down/Up):6.3 dB / 5.8 dB
Line attenuation (Down/Up):63.6 dB / 39.8 dB
Output power (Down/Up):16.9 dBm / 12.6 dBm
FEC Events (Down/Up):4859 / 0
CRC Events (Down/Up):42 / 0
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):397 / 0
Error Seconds (Local/Remote):1790 / 1089
1. Best Effort Test:                         -provides background information.
Download Speed
1.3 Mbps
0 Mbps
2 Mbps
  Max Achievable Speed
Download speed      achieved   during the test was - 1.3 Mbps
  For your connection, the acceptable range of speeds        is 0.8 Mbps-2 Mbps.
  IP Profile for your line is - 1.88 Mbps
2. Upstream Test:      -provides   background information.
Upload Speed
0.35 Mbps
0 Mbps
0.83 Mbps
Upload speed        achieved during the test was - 0.35Mbps
  Additional Information:
  Upstream Rate IP profile on your line is - 0.83 Mbps
