oxfordmatt
Message 1 of 10
ADSL2 Upload Speed Stuck
We recently joined BT broadband but after the ADSL training period the upload speed is stuck at 448kbps. The noise margin for upload is 17dB which seems very high. Can you please have a look why this is the case?
9 REPLIES 9
XRaySpeX
Recognised Expert
Message 2 of 10
Re: ADSL2 Upload Speed Stuck
Please post your full Router Stats. For a Home Hub see on here: Broadband Top Tips . Full router stats are key to any speed & connection issues.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
oxfordmatt
Message 3 of 10
Mode ADSL_G.dmt
Traffic Type ATM
Status Up
Link Power State L0
Downstream Upstream
Line Coding (Trellis) On On
SNR Margin (dB) 6.9 17.0
Attenuation (dB) 58.0 31.5
Output Power (dBm) 18.8 12.3
Attainable Rate (Kbps) 3344 980
Rate (Kbps) 3104 448
K (number of bytes in DMT frame) 98 15
R (number of check bytes in RS code word) 8 16
S (RS code word size in DMT frame) 2.00 2.00
D (interleaver depth) 16 4
Delay (msec) 8.00 8.00
INP (DMT symbol) 0.31 0.13
Super Frames 2292326 2292326
Super Frame Errors 33 0
RS Words 77939067 19486675
RS Correctable Errors 3997 0
RS Uncorrectable Errors 197 0
HEC Errors 102 0
OCD Errors 0 0
LCD Errors 0 0
Total Cells 285286514 0
Data Cells 23949908 0
Bit Errors 10411 0
Total ES 25 0
Total SES 0 0
Total UAS 39 39
imjolly
Message 4 of 10
your up speed is not stuck.  the problem is you are on adslmax and that is max up speed  see if mods can help you get on to adsl2  they will post here
XRaySpeX
Recognised Expert
Message 5 of 10
You are on the correct speeds for ADSL Max, not on ADSL2.
oxfordmatt
Message 6 of 10
Can we please be transferred to ADSL2?
JohnC2
Moderator
Moderator
Message 7 of 10
Hi @oxfordmatt Sorry you are not on the correct broadband product.
We will be happy to help you moved over to ADSL2 if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
XRaySpeX
Recognised Expert
Message 8 of 10
What exchange are you connected to? If you don't know use: http://www.samknows.com/broadband/exchange_search and post the URL of your exchange page.
oxfordmatt
Message 9 of 10
The exchange has ADSL2+ enabled, I just need to transferred to that service.
DavidM
Moderator
Moderator
Message 10 of 10
Hi @oxfordmatt,
Thanks for taking my call today. I'm glad I was able to get the order placed for you. Post back if you have any other problems and we'll be happy to help.
All the best
David
