Message 11 of 22
Re: ADSL2+ Yesterday a bit disappointed.
Thanks John and Edd, ishall be chasing them up shortly 🙂
Message 12 of 22
ok keep us informed
Newbie
Message 13 of 22
I was upgraded on the 25th, but only installed my new ADSL+ hardware yesterday.
I fear outside the 10 day training period. Smiley Sad
Stuck at 8,128 down and 448 up - should be up around 14
Will contact the custhelp detailed above.
Thanks for the link guys.
Message 14 of 22
hi your exchange may have been upgraded on the 25th but not all lines are moved over at the same time it cane from a few day to a few months while all the lines are moved over to the new service the training period does not start until your line moves over to the new system
Message 15 of 22
Now a week in not much change slight improvement speed up from 10,000 to 10,700 dsl connection  up from 12275 to 13358 ip profile up from 10830 to 11784. Few more days to go so hopefully will improve a little more,not as big an improvement as I hoped for suppose i will just have to wait for infinity to arrive for that.Strange when neighbours are getting nearer 15,000 download speeds.
Message 16 of 22
Hi could you repost your hubstats and a BT speed test for comparison then we can advise further
Message 17 of 22
looking at your old stats i would expect with a near perfect line approx 13.8 mb so to be honest if you are currently connecting at 13358k you are as near there as you will ever be as to your neighbours getting nearer 15000k that is easily explained no two phone lines are the same there attenuation (line length ) will be different to yours and there fore a different connection speed
Message 18 of 22
 Test1 comprises of two tests
1. Best Effort Test: -provides background information.
 Download  Speed
 10895 Kbps
0 Kbps21000 Kbps
Max Achievable Speed
 Download speedachieved during the test was - 10895 Kbps
 For your connection, the acceptable range of speeds is 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :13358 Kbps(DOWN-STREAM), 1208 Kbps(UP-STREAM)
 IP Profile for your line is - 11784 Kbps
2. Upstream Test: -provides background information.
 Upload Speed
 996 Kbps
0 Kbps1208 Kbps
>Upload speed achieved during the test was - 996 Kbps
 Upstream Rate IP profile on your line is - 1208 Kbps
Results Image not loaded
ADSL line status
Connection Information
Line stateConnected <script type="text/javascript"></script>
Connection time0 days, 03:40:07
Downstream13,358 Kbps
Upstream1,208 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.5 Annex A
Latency typeInterleaved
Noise margin (Down/Up)6.3 dB / 5.7 dB
Line attenuation (Down/Up)32.5 dB / 16.9 dB
Output power (Down/Up)20.8 dBm / 1.8 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)12247 / 0
CRC Errors (Down/Up)150 / 0
HEC Errors (Down/Up)3484 / 0
Error Seconds (Local/Remote)80 / 0
 Think I have hit the limits,router still keeps reseting,but is left on 24 7,noise margin a bit up tonight normally nearer 5db.
Message 19 of 22
I agree with john46 - after looking at your good stats you have a connection about as good as you will get with your attenuation
Message 20 of 22
Thanks everyone,for you responses,most helpful
