KevG123
Message 1 of 61
ADSL2+ on a Loooong Line - DAY 1
Before
Down 730k
Up     330k
Line Att 74.9db
After
Down 1.22Mb
Up      308k
Line Att 72.7db
Lots of training currently going on....
Fingers crossed but looking goodSmiley Happy
More stats to come..
60 REPLIES 60
Message 2 of 61
Re: ADSL2+ on a Loooong Line - DAY 1
crossed fingers.jpg  if that helps  lol
KevG123
Message 3 of 61
Thanks, it all helps !
I can see when I was switched over this morning with the modem reporting chipset change from Alcatel to Infineon and then sync speed going up
But its still reporting a Downstream rate cap of 8128 - isn't that ADSL Max rate max?
Also, I'm getting the better dload speed at snr of 6db - should that go down and speed get even higher?
I guess it all needs a few hours (or days) to settle
Message 4 of 61
check the modulation
992.1  adslmax
992.3  adsl2
992.5  adsl2+
KevG123
Message 5 of 61
I'm struggling to find that on the 2 Wire
Any ideas where that is shown?
Message 6 of 61
under protocol?
KevG123
Message 7 of 61
Under protocol its just says G.DMT Annex A
Crawled over all stats it reports but can only find the above
Message 8 of 61
that is adslmax  sorrySmiley Sad
Message 9 of 61
it is shown on the main hub stats page as ADSL2+
KevG123
Message 10 of 61
So if I'm still on ADSL max why the increase in speed and change of circuit? Could it be I'm in the middle of being changed over to ADSL2+ ?
I'll check my order to see if its still in progress...
