Message 11 of 61
Re: ADSL2+ on a Loooong Line - DAY 1
with your attenuation dropping by 2db maybe you have had a 'lift & shift' and got a better connection   with your long line adsl2 doesn't really matter and more importatnt is you seem to have a better faster conenction
Message 12 of 61
Yeah, my BT order has dissappeared from My BT page so I guess thats it
Really wanted to try it ...Smiley Mad
Message 13 of 61
do you recommend I give it til midnight tonite to see if original order is implemented?
How does this work then?
The mods put an order in for ADSL2+
Then someone decides not to fulfil the order?
Dont get me wrong, pleased to see my increase in speed, just want to undertand the process
Message 14 of 61
you can wait until tomorrow to see if any change in connection if not you can go back to mods.  or you can just settle for speed increase as I doubt adsl2 will give anymore and does bring a more aggressive system on any noise on your connection
Message 15 of 61
I just noticed that interleaving is now on so will want to get that changed back to fast
Need the lower ping rate for gaming
Message 16 of 61
that is because you line is unstable the next thing that will happen if interleaving does not stabilise your line is a noise margin increase and a reduction of connection speed
Message 17 of 61
Can we just summarise so I fully understand
Mod put an order in for ADSL2+ at my recently 21cn wbc upgraded exchange - friday being the day
Friday morning my stats showed me I was now on a different piece of kit - Infineon. Was Alcatel before
My attenuation dropped and my download speed increased from 720k to 1.2Mbs which is great
But whilst I'm on WBC I'm definatley not ADSL2+
I understand to get ADSL2+ is a physical move - so is that in addition to moving to WBC kit?
Also, even if my line 'doesn't support ADSL2+' if its a physical move there's no cct actually deciding if you can have ADSL2+ or not
Did someone at the exchange just decide my line was rubbish so they didn't fulfil the order and moved me to WBC but stopped short of ADSL2+ connection?
Sorry about all the questions, just would like to understand this
thx
Message 18 of 61
could you please post your full hub stats please then we can advise more
Message 19 of 61
Down Up
Rate:1440 kbs448 kbs
Max Rate:1332 kbs496 kbs
Noise Margin:6.0 dB8.0 dB
Attenuation:63.0 dB31.5 dB
Output Power:16.2 dBm12.4 dBm
Protocol:G.DMT Annex A
Channel:Interleaved
DSLAM Vendor InformationCountry: {46336} Vendor: {IFTN} Specific: {48753 }
ATM PVC:0/38
Rate Cap:1332 kbs
Attenuation @ 300kHz:63.0 dB
Uncanceled Echo:-13.3 dBOk
VCXO Frequency Offset:17.7 ppmOk
Final Receive Gain:34.5 dBOk
Excessive Impulse Noise:0Ok
Message 20 of 61
Best Effort Test: -provides background information.
 Download  Speed
 1.15 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.15 Mbps
 For your connection, the acceptable range of speeds is 0.8 Mbps-2 Mbps.
 IP Profile for your line is - 1.27 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 0.31 Mbps
0 Mbps0.45 Mbps
Upload speed achieved during the test was - 0.31Mbps
 Additional Information:
 Upstream Rate IP profile on your line is - 0.45 Mbps
