devonjem
Message 1 of 6
ADSL2+
Hello
I have just sigend up for BT broadband and know that my exchange is configured for ADSL2+.  However according to my router my line is using GDMT (something like that) and my speed is very slow.  If the exchange i am using is configured for ADSL2+ then can my line be similarly configured?
thanks
5 REPLIES 5
john46
Message 2 of 6
Re: ADSL2+
Hi Welcome to the community forums
Here is a basic guide to getting help from the community members done by CL Keith Please read through the link posted http://forumhelp.dyndns.info/speed/first_steps.html
once you have posted the information asked for then the community members can help you more
if using a hub 4 locate these lines located in the hub logs
Lines should look like this
19:11:29, 07 Nov. (2290101.460000) DSL noise margin: 7.00 dB upstream, 6.10 dB downstream
19:11:29, 07 Nov. (2290101.390000) DSL line rate: 448 Kbps upstream, 288 Kbps downstream
Thank You
This is a customer to customer self help forum the only BT presence here are the forum moderators
imjolly
Message 3 of 6
Re: ADSL2+
Enter your phone number and post results. Remember to delete number. https://www.btwholesale.com/includes/adsl/main.html
devonjem
Message 4 of 6
Re: ADSL2+
Thanks John.
Op Mode - G.DMT
Upstream - 448
Downstream - 3040
SNR Up - 10.0
SNR down - 3.0
Line Attn up - 31.5
Line Attn down - 60.0
My line does not drop out and is stable.  When i was with another provider i was in a similar position - using GDMT but the exchange was ADSL2+ enabled.  That provider reconfigured my line to use ADSL2+ and speed went up alot.
thanks
devonjem
Message 5 of 6
Re: ADSL2+
imjolly - thanks for that.  I used that link and the results are -
WBC ADSL2+ - downstream line rate up to 2, downstream range 1.5-3
ADSL max - downstream line rate up to 2.5, downstream range 1-4
Am i correct to think that other providers to my address use the same line and will all offer more or less the same speed so it does not matter, from a speed point of view, who i use?
thanks
imjolly
Message 6 of 6
Re: ADSL2+
all ISPs apart from cable will use the same line from the exchange to your home but an LLU provider uses their own equipment in the exchange providing an adsl2 service  with your attenuation you currently have a very good speed and a change to adsl2 assuming possible will make very little difference to your conenction speed but it does bring a more aggessive system on line noise.  you should however get about 100% increase in up speed
your down margin currently is low at 3db as normal about 6db which is the reason for your speed being above the estimated
