Chrissie1
Message 1 of 2
ADSLMax to ADSL2 Modulation upgrade
Hi, Is the any way that my line can be upgraded from my current ADSL MAX (g.992.1) modulation to ADSL2+ which is showing as available on my line. My previous case relating to this only upgraded my upload speed and it left the line modulation at 992.1 with no change in download speed as per my HH3 stats shown below. ADSL Line Status Connection Information Line state: Connected Connection time: 2 days, 22:25:49 Downstream: 4.5 Mbps Upstream: 864 Kbps ADSL Settings VPI/VCI: 0/38 Type: PPPoA Modulation: G.992.1 Annex A Latency type: Interleaved Noise margin (Down/Up): 5.5 dB / 11.0 dB Line attenuation (Down/Up): 45.1 dB / 25.5 dB Output power (Down/Up): 20.0 dBm / 12.7 dBm FEC Events (Down/Up): 66135 / 281 CRC Events (Down/Up): 146 / 66 ADSL Line Status Connection Information Line state: Connected Connection time: 2 days, 22:29:33 Downstream: 4.5 Mbps Upstream: 864 Kbps
1 REPLY 1
imjolly
Message 2 of 2
Re: ADSLMax to ADSL2 Modulation upgrade
did you get an email from the mods back in january when you previously posted?  if so try replying to that email
