RayW1
Message 1 of 11
AMC Channel on BT TV only?
I was under the impression that the soon to be launched 'AMC' channel was to be exclusive to BT TV subscribers only. Yet I notice today that a place holder has appeared on satellite for this service.
Does this mean that BT Sport subscribers (such as myself) that view via satellite will also be able to view this new channel ..?
10 REPLIES 10
scointer
Recognised Expert
Message 2 of 11
Re: AMC Channel on BT TV only?
Yes, it will be part of the sport pack if you pay for that..
RayW1
Message 3 of 11
Ah, thanks for that. I was under the impression it was only available via BT TV.
Roll on August 28th (the launch date according to the EPG data).
Time to start moaning for a HD version ..:-)
scointer
Recognised Expert
Message 4 of 11
If you want a HD version then you will need BT TV 😉
ozsat
Recognised Expert
Message 5 of 11
Is AMC confirmed HD on BT-tv?
using Superfast Fibre 2 Unlimited with BT TV Box Pro (UHD/HDR).
scointer
Recognised Expert
Message 6 of 11
Yes 😉 You don't think BT would pay for a high end exclusive channel and not show it in HD... Of course I guess you will need infinity 🙂
ozsat
Recognised Expert
Message 7 of 11
I have inifity - and the BT Sports in HD  -  so all good
scointer
Recognised Expert
Message 8 of 11
My advice is watch out around 23rd August 😉
stuartrogerson
Distinguished Guru
Message 9 of 11
Where is it on satellite?
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
scointer
Recognised Expert
Message 10 of 11
