TimCurtis
Guru
Message 11 of 30
Re: ASUS DSL-AC68U and BT Infinity 1 help
Can you provide the Max Data Rate & Data rate , both down & up , from the DSL log page?
adinis
Message 12 of 30
ASUS DSL-AC68U and BT Infinity 1 speeds help
Hello all, so after almost 2 months og fighting with BT to get me upgraded to BT Fibre 1 i have noticed that i am not getting my  "guaranteed speed" of 50MB. I have tested my speed on 4 different sites and including BT Performace Test page and i am only getting a max of 37.65MB. I was on those with BT, well on a chat and then they called me, and we where up to the part where they wanted to test the socket using the testing connection but they wanted me to connect the BT Hub 6. Before i started an argument with them as to why i did not want to use the BT Hub i told them i would do it later and contact them tomorrow as i didnt want to waste my time. So for those using this router are you getting the guaranteed speeds that BT claims to be delivering. By the way all my tests have been done while connected via ethernet. Also router is up to date on firmware. Thanks in advance.
Keith_Beddoe
Message 13 of 30
Re: ASUS DSL-AC68U and BT Infinity 1 speeds help
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
You will need to plug the HH6 into the test socket, and go to this page with a computer connected to the home hub.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
The guaranteed minimum speed is the connection speed, not the download speed.
adinis
Message 14 of 30
Sorry for the late reply. Here is the info you requested.
Keith_Beddoe
Message 15 of 30
@adinis
Why did you start a new thread?
I have merged the two together.
licquorice
Message 16 of 30
I suspect your port in the green cabinet is wrongly configured as 40/10 instead of 55/10.
adinis
Message 17 of 30
Sorry for that. Here is the first part of the requested info. I will upload the rest tomorrow once i test with BT HH6BT Availability Checker.JPG
adinis
Message 18 of 30
if thats the case how in the hell am i going to get BT to fix that? took  me 2 moths and dealing with complaints department just to try and get Fibre Smiley Mad
licquorice
Message 19 of 30
No need, the info required can be seen from your ASUS screenshot. Its not an ASUS problem.
licquorice
Message 20 of 30
Thats the hard part. However, unless you are regularly streaming multiple UHD film channels or downloading huge multi GByte files you will never tell the difference between 40 and 55.
