Geoff_UK
Message 1 of 18
ASUS DSL-AC68U
Hi,
Finally got fed up with poor wireless coverage with the HH5 and opted for the above modem/router combo.
Only got it yesterday and initially all seemed good - ping was about 15 or 16 and acheivable download speed went from 68 to 71 and upload stayed constant at about 18.8
On the DSL stats page, the connection was "fastpath", but there were a lot of CRC errors building throughout the day - was at about 24,000 by the time I went to bed.
This morning, the stats are as follows:
ping is now 22-23 and download is about 66-67 Mbps - upload has remained the same, at about 18.8Mbps
Is the interleaving on the downstream a "learning" phase?  If not, can I do anything about it ??
As always, any and all help/asistance greatly appreciated
17 REPLIES 17
imjolly
Message 2 of 18
Re: ASUS DSL-AC68U
is there any noise on quiet line test?
The DLM has reset your connection with lower connection speed but also changed latency from fast to interleaved probably due to the error build up you mention
Geoff_UK
Message 3 of 18
Re: ASUS DSL-AC68U
on the quiet line test, all I can hear is a very faint "hiss", no crackles or pops
imjolly
Message 4 of 18
Re: ASUS DSL-AC68U
any noise on quiet line test with corded phone is not good and certainly wont help your broadband connection  if cordless then a dull hum is normal
Geoff_UK
Message 5 of 18
Re: ASUS DSL-AC68U
I'll try and dig out a corded handset and try again
LS26
Message 6 of 18
Re: ASUS DSL-AC68U
this is on my RT AC68U I binne home hub it drooped network every day this is brilliant
Download Speed
 58.44 Mbps
0 Mbps65.67 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 58.44 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-65.67 Mbps .
 Additional Information:
 IP Profile for your line is - 65.67 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 14.77 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 14.77Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Geoff_UK
Message 7 of 18
Re: ASUS DSL-AC68U
no luck on finding a corded phone - will have to "borrow" one from work !!
TimCurtis
Guru
Message 8 of 18
Re: ASUS DSL-AC68U
How do your settings compare to mine?
Geoff_UK
Message 9 of 18
Re: ASUS DSL-AC68U
here is my page like that - slight differences - I "think" i'm using the latest firmware??
TimCurtis
Guru
Message 10 of 18
Re: ASUS DSL-AC68U
Yes you've got a later firmware than me but differences in settings aren't significant I think.
Mine's been running these settings for a year or so & it's been remarkably stable.
I think give the DLM a chance to make some adjustments over the next week or so, keeping reboots to an absolute minimum.
When I switched from Infinity 1 40/10 to 52/10 my ping shot up as did my errors but the DLM soon sorted that out & upped my speed to an all time high.
