Anonymous
Not applicable
Message 41 of 57
Re: ASUS DSL-AC88U Router and BT Sport
You can't be the first one on this forum to use one of those routers, do a search and see what you can find
Message 42 of 57
I have had a look on this one and the Asus forums.
The only one that mentions BT Sports said he took it back because he couldn't get it working, but that was two years ago
https://community.bt.com/t5/Archive-Staging/ASUS-DSL-AC88U/td-p/1783721
Anonymous
Not applicable
Message 43 of 57
Sorry, I'll have to pass on that one
Anonymous
Not applicable
Message 44 of 57
Try this one, I found it by searching Google for asus DSL-AC88U ipc6023
https://community.bt.com/t5/Home-setup-Wi-Fi-network/Asus-DSL-AC88U-with-BT-TV/m-p/1869686#M153996
Message 45 of 57
@Anonymous @licquorice @TimCurtis
I did see that other post but had rather hoped that with new firmware this problem would have gone away.
Many thanks for your help with this one - unfortunately it looks like this router is going back to Currys.
Any recommendations on Router/Modem combinations that are proven to work with BT Sport and give a good coverage as well as speed?
Anonymous
Not applicable
Message 46 of 57
Sorry no, I use the BT supplied one. The TP-Link ones get a lot of mentions and seem to be quite popular on here though
Message 47 of 57
@Anonymous
Thanks for all your help - it is deeply appreciated. I’ll do more research on compatibility with BT Sport before I buy anything else.
Message 48 of 57
@RugbyNut
I use the Asus DSL-AC68U which gives excellent wifi coverage and perfect BT Sport reception. Also alot cheaper than the AC88U. Still in stock at Curry's.
The only longer term downside is that it doesn't support G.Fast broadband.
Message 49 of 57
@TimCurtis
Thank you for this any your previous posts - I'll give this router a look.
Message 50 of 57
@RugbyNut
Thought I'd just add something about the wifi coverage.
Ours is a large 4 bed semi built 1926 so solid walls etc.
The router is in the centre of the house on the upstairs landing and in all rooms I get near max speed (45meg) on any wifi device.
Our garden is 30m long & I can get near 20meg at the bottom of the garden so I'd say that's pretty good.
