Message 1 of 16
Abbeyhill, Edinburgh exchange
Hi,
When I check my exchange on the openreach checker, it says Accepting Orders.
Is there any way to find out when a particular cabinet will be upgraded?  There used to be a phone box at the top of my road but this has now been replaced with a big green cabinet.  I live approx 300 metres from the exchange
Many thanks,
Colin
15 REPLIES 15
Message 2 of 16
Re: Abbeyhill, Edinburgh exchange
enter your phone number and see if a cabinet number or E/O  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 16
Thanks for the reply.
Checked that link but no mention of FTTC/P
Distinguished Guru
Message 4 of 16
Does it give you a cabinet number?
If not, I'll try again 🙂
Message 5 of 16
Sorry, forgot to add that
Cabinet 31
Message 6 of 16
then send email here with phone number and exchnage and openreach will reply in about 10 days nga.enquiries@openreach.co.uk
Message 7 of 16
Ah excellent will do.
Thanks for your assistance
Message 8 of 16
Time to bump!
Well there seems to be no movement on Infinity upgrade since this original post.  Several enquiries with BT over the past year have promised I would be getting Infinity by the end of June 2014, then end of October 2014 and the definitely by end of December 2014.
On using the Openreach Where & When checker the status has changed to Exploring Solutions (whereas it used to be Enabled Area) when I check with postcode.  If i check using my landline number then the checker says Under Review.
I have used the various feedback options I have seen on these forums to try and gain extra information but have not received a reply at all.
Obviously I have no idea of the technicalities behind the upgrade but I do know that the exchange is enabled and that other users have infinity in the area.  As I have said in earlier messages I live about 300m from the exchange and about halfway between there used to be a phone box which was taken down and replaced with a green cabinet.
If anyone or any mods could offer some information I would be extremely grateful.
Many thanks,
Colin
Message 9 of 16
post the results from entering your phone number  remember to delete number https://www.btwholesale.com/includes/adsl/main.html
Message 10 of 16
it appears there are technical problems in commissioning the the cabinet and Openreach are researching other optional services to provide a faster service
