horseunderwater
Message 1 of 6
Access control not working as it should
Access control on my hub 2 is not allowing access on my daughters computer at the correct times m it`s been keeping her off all the time
5 REPLIES 5
horseunderwater
Message 2 of 6
Re: Access control not working as it should
I will shamelessly bump this please someone help
Message 3 of 6
I am sure I saw a post on here before similar and I think the reply was that you cannot set the access time if when you are doing it you are actually in that time frame.  Maybe I got it wrong but memory is not what is used to be.Smiley Wink
Distinguished Guru
Message 4 of 6
If you disable Access control, does the laptop then connect?
To temporarily disable BT Access Control for all devices without deleting any of the control rules:
1. click No next to Enable Access Control
2. click Apply
To disable BT Access Control:
1. click Delete opposite the device you wish to remove access control
2. click Apply
Also what time is access control set from and to?
-+-No longer a forum member-+-
horseunderwater
Message 5 of 6
if i disable access control the pc connects ok. time is set from 2100 to 0700
Distinguished Guru
Message 6 of 6
Odd one for sure.
The 2100 to 0700 is the default setting. Have you tried using different times (30 min increments).
or maybe (not too sure if it would make a difference)
Set your daughters laptop so that it has a fixed IP address, then retry access control.
