Corrdun
Newbie
Message 1 of 3
Access control
Hi I was looking at access controls on my hub and was wondering why there was so many devices that was not mine?
Any info would be great
Like wether they should be there or not?
Tags (3)
2 REPLIES 2
hamish72
Recognised Expert
Message 2 of 3
Re: Access control
Should list all devices that have ever had access at any time as far as I am aware even the ones you have forgotten
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Tags (4)
Message 3 of 3
Re: Access control
Just as a guide, this may help.
192.168.1.253  Internal USB port on hub
If you have BT Vision you will see an entry for the BT Vision Box
If you are using the powerline adapters, then there will be another two entries.
So possibly four in total, none of these will be shown as wireless connections.
