profitxchange
Message 1 of 9
Access to Broadband usage??
I have unlimited Broadband - but I would like to be able to check my usage.
Your helpline has advised that I cannot access this info via "MY BT" account which sssms a bit dumb.
As an alternative might it be possible to include Broadband usage on the bill?
8 REPLIES 8
conrad
Recognised Expert
Message 2 of 9
Re: Access to Broadband usage??
Seen any flying pigs recently Smiley Very Happy
It's not going to happen unfortunately just like names appearing on current phone call usage.
pottyperson
Distinguished Guru
Distinguished Guru
Message 3 of 9
BT consciously uncoupled unlimited customers from the usage monitor a few years back; there was a workaround but they eventually closed that off too. There was some BS given as to why the monitor was unhelpful to unlimited customers, but no better explanation for the change ever emerged than that it was simply a ploy to discourage low users from downgrading.
My guess is that the limited option will disappear at some point, though mucking customers about meanwhile does BT no credit.
profitxchange
Message 4 of 9
With BT making life more and more complicated with their packages and poorer customer care I will probably change to exclusively mobile (not bt) when we move house - it will cost half the price and can't be any worse.
XRaySpeX
Recognised Expert
Message 5 of 9
You could install a usage monitor like Broadband Meter but it would only be for each PC.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
profitxchange
Message 6 of 9
thats a thought
thanks
profitxchange
Message 7 of 9
Tried BB meter but is seems to be very very slow. will look for alternative. Thanks for the idea.
XRaySpeX
Recognised Expert
Message 8 of 9
You could try Download NetMeter - MajorGeeks . It's nicer than the other 1 but hasn't worked for me since Win 8.
profitxchange
Message 9 of 9
Thanks for the alternative
I have found Shaplus which I am trying - basic but  seems to do what I need
http://www.shaplus.com/bandwidth-meter/
Willl also take alook at your latest suggestion
Thanks again
