Message 1 of 9
Access to WiFi QR code?
Is there anywhere I can access a digital version of my QR code and login details, please?
I've searched the MyBT app and can't find one. Also tried sticking the sticker onto some paper and scanning it at high resolution, but it's still not clear enough.
It's a large house and I only got one sticker of the login deets and I'd like to make copies to put in all the rooms.
Thanks in advance!
Tags (4)
8 REPLIES 8
Message 2 of 9
Re: Access to WiFi QR code?
Why bother with WiFi security at all if you intend to display the details to all and sundry!!
Message 3 of 9
You should be able to do it from an Android phone.
See, for example
https://uk.pcmag.com/networking/132359/how-to-wirelessly-share-your-wi-fi-password-on-iphone-or-andr...
Message 4 of 9
In the bedroom drawer of each family member, not displayed at my window 😉
Message 5 of 9
Thank you, Graham. That's perfect! 🙂
Message 6 of 9
If it's only for family members, once they have logged in the first time they will no longer have to use the password again as the details will be stored on their devices.
Message 7 of 9
Thank you, but I find myself needing them regularly. Tech often goes wrong and things need resetting.
Message 8 of 9
Might be simpler to change the password to something memorable you can just quote rather than a jumble of characters.
Message 9 of 9
The hub wifi doesn't have a QR code in any case, the QR code is the admin password for the hub.
