CedricTheBrave
Message 1 of 7
Access to parental controls is missing
I cannot find the option to access parental controls on mybt login.
it also fails to enable a website f its blocked and i follow the unblock for an hour option
can anyone help sorting out my access to the option?
many thanks
6 REPLIES 6
DavidM
Moderator
Moderator
Message 2 of 7
Re: Access to parental controls is missing
Hi @CedricTheBrave and thanks for posting.
Do you see the parental controls tile in your extras section or is it greyed out? Have you enabled it previously?
Cheers
David
CedricTheBrave
Message 3 of 7
CedricTheBrave
Message 4 of 7
i am sure i enabled it when the account first was setup but that was a few years ago
DavidM
Moderator
Moderator
Message 5 of 7
Hi @CedricTheBrave,
Thanks for checking that. We'll need to take a closer look at this so can you send over your details? You'll get the contact the moderators link in my profile. We're very busy at present so it's taking longer than expected to reply but once you submit the details we'll get to you in turn.
Cheers
David
CedricTheBrave
Message 6 of 7
is that the normal contact form or a specific one for contacting moderators? as i cannot see one of those
DavidM
Moderator
Moderator
Message 7 of 7
Hi @CedricTheBrave,
Sorry for any confusion. If you click on my profile you'll see ******click here to contact the moderators****. Click there and complete and submit the webform and either myself or one of the other mods will pick up.
Cheers
David
