Hi I have bought 3 BT whole house discs they work fine, however does anyone know if or how it is possible to control the wifi discs from the app across the internet ? the app works fine on the same network
any direction greatly appreciated
thanks
Solved! Go to Solution.
No, that is not possible. It has to be connected to the same network as the discs.
