Hi,
My Home Hub (version 6) has been set up so that I can access my CCTV DVR and it appears to work in most cases but there is one combination that does not work. Can anyone advise me whether there is something else that needs to be set up - or is what I am trying to do just not possible!
1) I can see the CCTV system from within the home network by specifying the internal IP address of the DVR - so that's good.
2) I can access the CCTV system away from home by specifying the DDNS address that I have set up - so that's good too.
3) What I cannot do is to use the DDNS address on my mobile phone when it is connected to my home hub via wifi
Thus I'd be connected to the home hub via wifi, going out across the internet to the DDNS server to get the external IP address of the home hub and then connecting back through the home hub to the CCTV DVR. Is this even possible?
Thanks for your help.
Stay safe!
Bill
No, that isn't possible, home hubs don't support NAT loopback.
Thanks - I can now stop trying to make it work!
Yes it's possible, I do it with a Foscam Camera.
I have my app configured for an Onvif camera and monitor the RTSP stream using RTSP over TCP.
If it helps, the app I'm using on my phone is tinyCam pro.
Format is rtsp://{username:password@DDNS Address:Port/stream ID}
Note that it will only work using RTSP over TCP
Hmm, presumably you are not connecting to the camera directly but are connecting to a cloud service which is triggering the camera to stream to the cloud which you are then monitoring.
No, my camera's far too old to use a cloud service. Just DDNS.
Then I'm struggling to see how it works without NAT loopback. Protocol used shouldn't make any difference.
My camera is an old Foscam one which I've had since it was new, in that time I've accessed it as described by the OP bullet point 3 with a HH5, HH6 and now SH2. Bit rate and FPS are nothing to write home about but it works
Are you sure you are not connecting via your LAN rather than via your public IP address.
Positive.
I have an app on my phone to monitor the camera whilst I'm away from home which requires DDNS. I also use it occasionally when I'm at home using the same settings and on wi-fi
