MrVW
Message 1 of 4
Accuracy of the PCP Spreadsheet
Hi all, just a quick question, how accurate is the PCP spreadsheet that was leaked?
The reason i ask is that it states that my post code is served by Cab 53 and that 100% of lines on that postcode are served by that cabinet. this cab has a FTTC cab installed already which i was happy about as i though thats the cab i was connected to and once the exchange goes live it wouldnt be long till i could get infinity.
SAU_IDNamePostcodeSAU_NODE_IDExchange Only FlagPercent LinesUpliftPhaseDeployedFTTC or FTTP
EMBURTOBURTON UPON TRENTDE130TY{EMBURTO}{P53}0100%9.417bYesFTTC
but if do an enhanced line characteristics check via the openreach portal it says my PCP is number 8, ive looked on the spreasheet and Cab 8 is not on it so i cant verify which postcodes it serves.
Line characteristics
You searched for telephone number
CSS Exchange:BURTO/ BURTON ON TRENT
District code:EM
BT Post code:DE13 0TY
PCP Id:8
DP Number:5490
ANFP Category:L
Circuit line length estimate:4784
Circuit line length calculated:4120
DP Line length estimate:4675
A – Earth capacitance:238
B – Earth capacitance:247
Celerity line loss:64.3
LLC Line loss:65.98
BET Enabled:N
Is there anyone at BT who can verify which Cab my line is connected to?
3 REPLIES 3
loudgraham
Message 2 of 4
Re: Accuracy of the PCP Spreadsheet
how do i do that characteristic test please ?
rickydg
Message 3 of 4
Those advanced stats are restricted for openreach and clients use only. He must've got a leaked username from somewhere.
MrVW
Message 4 of 4
Their my logins, i work for a CP
