Message 1 of 4
Activate Fon on my router
I was activated for Fon on my router but somewhere along the way, it was reset and it now shows that I am not activated even though my BT WIFI account is active.
There does not seem to be any way to re-activate the service on my router that I can find. Suggestions please.
3 REPLIES 3
Message 2 of 4
Re: Activate Fon on my router
If you do a factory reset, its normally enabled by default.
Distinguished Guru
Message 3 of 4
is there any real reason why you need it activated on your home hub? you would still be able to access the btwifi hotpots whilst out and about
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
I have the same problem. It does not affect me directly, but when some of my friends visit, who have BT Broadband accounts, they cannot use BTWiFi as my Home Hub 5 is not broadcasting the network. I don't give them access to my own private network as some of them are cowboys so I made a rule that nobody uses my own network to exclude the possibilities of them gaining any access to my computers.
