Message 1 of 17
Activated yet no internet
I have been waiting for some time now, after I've been told to check serial number which I have responded to the person who mailed me, after I've been told it will be on 19th and to wait for Monday still nothing. Can do one please fix my internet which I have to pay for which i think is unfair as why do I have to pay for something I've not even experience yet?
Here is my info as I know I'll be asked for this:
1. Product name: BT Home Hub
2. Serial number: +068343+NQ44113649
3. Firmware version: Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version: BT Hub 5A
5. WAN: PPP Disconnected (Login Failed)
6. Data sent/received: 0.0 MB / 0.0 MB
7. Broadband username: bthomehub@btbroadband.com
8. BT Wi-fi: No
9. 2.4 GHz Wireless network/SSID: BTHub5-MC7P
10. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 150 Mb/s)) 20 MHz, WPS enabled
11. 2.4 GHz Wireless security: WPA2
12. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
13. 2.4 GHz Wireless network/SSID:
14. 2.4 GHz Wireless connections: Disabled
15. 2.4 GHz Wireless security: None
16. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
17. 2.4 GHz Wireless network/SSID: BTWifi-with-FON
18. 2.4 GHz Wireless connections: Disabled
19. 2.4 GHz Wireless security: None
20. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
21. 2.4 GHz Wireless network/SSID: Auto-BTWiFi
22. 2.4 GHz Wireless connections: Disabled
23. 2.4 GHz Wireless security: None
24. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
25. 2.4 GHz Wireless network/SSID:
26. 2.4 GHz Wireless connections: Disabled
27. 2.4 GHz Wireless security: None
28. 2.4 GHz Wireless channel: Automatic (Smart Wireless)
29. 5 GHz Wireless network/SSID: BTHub5-MC7P
30. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s)) 80 MHz, WPS enabled
31. 5 GHz Wireless security: WPA2
32. 5 GHz Wireless channel: Automatic (Smart Wireless)
33. 5 GHz Wireless network/SSID:
34. 5 GHz Wireless connections: Disabled
35. 5 GHz Wireless security: None
36. 5 GHz Wireless channel: Automatic (Smart Wireless)
37. 5 GHz Wireless network/SSID: BTWifi-with-FON
38. 5 GHz Wireless connections: Disabled
39. 5 GHz Wireless security: None
40. 5 GHz Wireless channel: Automatic (Smart Wireless)
41. 5 GHz Wireless network/SSID: Auto-BTWiFi
42. 5 GHz Wireless connections: Disabled
43. 5 GHz Wireless security: None
44. 5 GHz Wireless channel: Automatic (Smart Wireless)
45. 5 GHz Wireless network/SSID:
46. 5 GHz Wireless connections: Disabled
47. 5 GHz Wireless security: None
48. 5 GHz Wireless channel: Automatic (Smart Wireless)
49. Firewall: Default
50. MAC Address: d0:84:b0:da:1c:e0
51. Software variant: -
16 REPLIES 16
Distinguished Guru
Message 2 of 17
Re: Activated yet no internet
Please confirm that today is your activation date.
It can be up to midnight tonight.
If not, I'll try again 🙂
Message 3 of 17
Activation date was the 19th...
Distinguished Guru
Message 4 of 17
Do you have that in writing?
Message 5 of 17
No in writing it was suppose to be the 9th, then the 17th then the 19th. On my order status it shows the 19th and shows as complete. Today I got a text saying "we have activated your BT but have noticed you have not been using it" ...?
Message 6 of 17
as this appears a self install are you conencted to the master or better still the test socket with a new filter?  does your phone work ok?
Message 7 of 17
I don't have a phone. I'm connected to the open reach modem via port 1.
Message 8 of 17
It's a new built building the engineer was here the 17th to setup phone line.
Message 9 of 17
so you actually don't know if phone is currently working  did engineer install this type of master  fibre SSFP.jpg
Message 10 of 17
I don't know. There is a fibre box, then a open reach modem, then the router. Everything has green lights except the router
