imjolly
Message 11 of 71
Re: Actual Speed versus Contract Speed
from looking at the results of dslchecker the estimate is about 4.5mb connection
is it posiible to post stats from hub  if not sure then which version of hub do you have
imjolly
Message 12 of 71
If you are using a BT hub which version is it?  If the newer hh6 then go to advanced settings then technical log and post data
lyn6
Message 13 of 71
his is a list of your BT Smart Hub settings and current statistics.
Product name:
BT Hub 6A
Serial number:
+084319+NQ71866797
Firmware version:
SG4B1000B316
Firmware updated:
02-Sep-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 29 Minutes 24 Seconds
Data rate:
448 Kbps / 4.42 Mbps
Maximum data rate:
1248 / 6116
Noise margin:
27 dB / 11 dB
Line attenuation:
41.5 dB
Signal attenuation:
20 dB / 41.5 dB
VPI / VCI:
0/38
Modulation:
G_992_1_ANNEX_A
Latency type:
Fast Path
Data sent / received:
49159 MB Uploaded / 49191 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Active
2.4 GHz wireless network name:
BTHub6-C3HP
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
BTHub6-C3HP
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
7.33.1
lyn6
Message 14 of 71
Was that what you needed??
imjolly
Message 15 of 71
Yes that is the stats I was looking for
you have been put on adslmax up to 8mb but should be on adsl2/2+ which should increase your down speed but will increase your up speed to nearer 1mb.
See if forum mods mods can sort out and get you moved to adl2. They will post help here
lyn6
Message 16 of 71
Thank you so much for your time and patienceWill the mods pick up from this thread or do I need to flag them?
Thanks again
JohnC2
Moderator
Moderator
Message 17 of 71
Hi @lyn6 Sorry you are not on the correct profile.
We will be happy to help you get changed over if you send us your details. You can contact us by clicking on my user name and selecting contact the mods.
John
imjolly
Message 18 of 71
@lyn6
Just use the mod contact us link and complete the form. Mods will then get back to you when your firm reaches to of queue probably 3/5 days
lyn6
Message 19 of 71
Many thanks
imjolly
Message 20 of 71
Please post back and let me know how you get on
