lyn6
Message 21 of 71
Re: Actual Speed versus Contract Speed
For sure
XRaySpeX
Recognised Expert
Message 22 of 71
You've actually been put on the "Up to 8 Meg" ADSL Max instead of the "Up to 24 Meg" ADSL2+ that you were promised at sign-up.
On ADSL Max you should be getting about 6.5 Meg Data rate. Were you to move to ADSL2+ you would get about 7.2 Meg Down but your Up Data rate would be about 1 Meg.
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
lyn6
Message 23 of 71
@XRaySpeX I signed up for the up to 17meg package although I was promised only 8meg - don't know why they can't do up to 17meg. I could cope with this if it was what I was getting but the 3meg  that I am getting is ridiculous. Thanks
imjolly
Message 24 of 71
you can only get as fastas you line can handle which is shown in the dslchecker results
lyn6
Message 25 of 71
But swapping to adsl2/2+ SHOULD help @imjolly ?
imjolly
Message 26 of 71
Yes if you look at dslchecker results you are on adslmax and moving to adsl2/2+
lyn6
Message 27 of 71
Thanks Imjolly
imjolly
Message 28 of 71
with your attenuation I would be looking for about 8/9mb connection speed
XRaySpeX
Recognised Expert
Message 29 of 71
@imjolly: Yes, I'd go by the attenuation rather than the BTw Checker.
Yes, at the current attenuation, 41.5 dB, ADSL2+ will give 8-9 Meg, but generally going from ADSL Max to ADSL2+ the attenuation increases by 3 dB. So I'm saying about 7 Meg.
XRaySpeX
Recognised Expert
Message 30 of 71
Yes, that's ADSL2+. By advertising rules BT can only advertise it as "Up to 17 Meg" but technically it is really "Up to 24 Meg".
