Message 1 of 5
Adding WiFi to BT Mini Connectors
I currently have a pair of BT Mini Connectors linking my BT router and BT TV box. I'm getting v.poor wifi in the  converted loft and would like to add a compatible device that hooks up to the powerline network, but generates a WiFi signal. Does BT produce a device that will do this?
I'm afraid I get rather lost in the multitude of different product descriptions on the BT site, but a number of the products on the BT site here, which profess to be powerline adapters, actually appear to be wifi extenders:
https://shop.bt.com/category/networking,network-devices,powerline-adapters/11301-50910
If BT don't produce something that will do this, will this Devolo device speak to the BT Mini Connector which is connected to the router?
https://shop.bt.com/products/devolo-magic-1-wifi-add-on-adapter--2x-lan--pass-thru--8353-FSBP.html
Any help much appreciated.
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Adding WiFi to BT Mini Connectors
The neatest solution is to replace the mini connectors with something like this
https://www.bt.com/help/user-guides/broadband-and-wi-fi-devices/wi-fi-and-home-networking/wi-fi-home...
Message 3 of 5
Thanks, but they appear to have been discontinued and also I don't really want to discard the mini connectors that I've already paid for. Is there an alternative?
Anonymous
Not applicable
Message 4 of 5
There is if you've got an old hub
Message 5 of 5
These are still available.
https://shop.bt.com/products/bt-mini-wi-fi-home-hotspot-600-kit-084288-BVFF.html
If you just want to add a wireless connection, then a wireless access point is all you need, like this.
https://www.tp-link.com/uk/home-networking/access-point/tl-wa801nd/
Or https://www.tp-link.com/uk/home-networking/access-point/tl-wa901nd/
This simply plugs into one port of the mini connector.
