1TonyCurrie
Message 1 of 12
Adding a 5 port switch to HH3 - help please?
As you know the HH3 has a gigabit port, I have a NAS that also has a gigabit port, so I have plugged my NAS into that - that way the NAS can transfer at 1000mbs.  My LAN adapter on my pc is gigabit enabled, but because it connects via the 100 meg ports i dont get get a gigabit connection.  I have just ordered a Netgear switch so that I can have a full gigabit network.
Can somebody please explain to me what I plug into where when it comes - I dont want to mess anything up.
Thanks in advance.
11 REPLIES 11
proterra
Message 2 of 12
Re: Adding a 5 port switch to HH3 - help please?
You have to alter the properies of your Lan adaptor in device manager and go through all the tabs and there settings . I'm at work so cant check. but there is a setting to choose between 10 or 100 or automatic. I bet its set to 100 so choose automatic, disconnect and reconnect and you should have a 1000 gigbit network connection. I had the same problem recently and it took me agaes to figure out
1TonyCurrie
Message 3 of 12
Thanks for the reply, there is no setting for 1000mbps, however if i plug my lan cable into the gigabit port on the homehub it does pick up the 1gb connection.  But then I have used my gigabit port, so I have ordered a switch so my NAS can operate at that speed too, as your network is only as quick as your slowest connection.
I just need to know what to plug into where - in short I can have my PC showing as 1gb, but NAS not or vice versa hence orderering the switch - hope that makes sense?
proterra
Message 4 of 12
I would think that you just the NAS & PC into the new switch and then to the HH3 that should do it. Isnt there a USB on the HH3? would that be quicker?
Just seen this another forum
If anyone is interested, I've just connected an external 500GB NTFS formatted hard drive to the USB port on my HomeHub V3 and it works fine, quick enough to play video.
1TonyCurrie
Message 5 of 12
Hmmm, not sure I do know that in theory a gigabit connection is more than twice USB 2. I cannot connect my nas via USB it has an ethernet port only unfortunately.
I wonder if I plug a cable between the gigabit port on the HH3 and the switch, then just plug the pc and NAS into the switch?
Rottie
Expert
Message 6 of 12
Hi there,
Here's what I would do in your situation:
Firstly run a length of CAT5E or CAT6E cable between the Gig-E port on the hub and the switch, then just run a length of CAT5/6E from the switch to each of the peripherals that require gigabit access.
It doesn't matter what ports you plug your peripherals into; they'll all the same and don't need to be populated in any specific order. 🙂
I hope this info helps. 😄
1TonyCurrie
Message 7 of 12
Thanks very much for the reply Rottie,
I will let you know if it works 🙂
proterra
Message 8 of 12
Jumping on the bandwagon . My son has his Xbox and PC plugged into a gigabit switch in mhis bedroom. this is connected by 85Mbs Homeplugs at present to the HH3 . So even if I get 250Mbs Homeplugs thts themax it bwill run at not 1000mbs? I would need another gigabit switch at the hh3 end cos I'm using the Gige port for my PC.
Is there a better way ? running cables not possible due to fitted wardrobes etc.
Rottie
Expert
Message 9 of 12
Hi there,
Unfortunately, you won't be able to give the Xbox gigabit access. 😞
The Xbox only has a 10/100 ethernet adapter on-board, so it physically can't connect/achieve throughput over 100Mbps.
Sorry to be the bearer of bad news. 😞
proterra
Message 10 of 12
OK but my sons PC has a gigbit card and feeds into the gigabit switch, neither are on at same time (uses TV as monitor for both) . But wont I only get the max speed of tjhe homeplugs ie 85mbs at present or 200 when I upgrade?
