Message 11 of 14
Re: Adding a device to Network Home Hub 3
@aangus wrote:
do i need to go to port forwarding ?
I only have a blu ray and my computer wired to the hub.
thanks
No, port forwarding has nothing to do with it, thats purely for routing incoming connections from the Internet, to devices on your network.
Look at the BluRay network settings option, and see if there is a manual network settings option. Most devices have one.
Then you can manually enter the following.
IP address 192.168.1.50
Subnet mask 255.255.255.0
Default gateway 192.168.1.254
DNS server   192.168.1.254
Message 12 of 14
Understood Keith,
Tags (1)
Message 13 of 14
I am successfully downloading an UPdate!
thanks Keith
Message 14 of 14
Excellent Smiley Happy
There is an issue where certain devices issue a DHCP request (Asking for IP address, gateway and DNS servers), and the composition of the request is not understood by the home hub 3, why this is, I do not know.
Some mobile devices like tablets, and smartphones seem to suffer most from this problem. Sometimes, after repeated requests, it sorts itself out.
Using static IP settings avoids this issue.
