SuperFlyGuy99
Message 1 of 6
Adding to Hotspot 500 kit
I currently have a hotspot 500 kit installed, the passthrough is connected to my HH5 and two PCs via hardwire and the wifi extender cover the upstairs by wifi and hardwire.
I need to add another hardwire passthrough into the garage and ideally another wifi extender at the back of the house.
Can i simpley use a Hotspot 600 kit and just plug it in to the wall sockets or would the 600 kit need to be connected by hardwire to the HomeHub.
Ultimately can i use two kits together but with only one connected to the HH5
5 REPLIES 5
licquorice
Message 2 of 6
Re: Adding to Hotspot 500 kit
You can only connect one extender to the home hub, just add hotspots as required.
SuperFlyGuy99
Message 3 of 6
Thanks but trying to find a pack containing one hardwire passthrough and one hotspot has so far been impossible.
licquorice
Message 4 of 6
Not sure exactly what you mean by 'hardwire passthrough'
SuperFlyGuy99
Message 5 of 6
Also, according to a post on Amazon, each unit can either send or recieve so surely both can recieve if just added to an inplace kit.
Ref passthrough, an adaptor that has another socket on it (passthrough) and both hardwire (Ethernet) and wifi (like in the 500 kit).
licquorice
Message 6 of 6
Ok, I think we are talking at cross purposes here. You can only have one unit connected to your hub, that will then feed any number of 'slave' units plugged into mains sockets. You can't have 2 separate networks by connecting 2 units to your hub. It doesn't matter if the 'slave' units are providing an Ethernet socket or wifi or both.
