Message 1 of 3
Additional Phone
Hi.
I just upgraded to the Smart Hub 2 with Digital Voice and with the Advanced Digital Home Phone - with Alexa built-in. I want to get an additional phone as an extension but don't necessarily need Alexa on it. Am i forced to get the same type of phone or is there another option that will work along side the Alexa phone with the compatibility of- say - transferring calls or automatically updating contacts etc.
2 REPLIES 2
Message 2 of 3
Re: Additional Phone
You can buy the cheaper essential DV phone which is compatible
Message 3 of 3
Thanks for the quick response. I'll check this out.
