DS
Distinguished Guru
Message 21 of 36
Re: Admin Password not working, need to check settings
Are there any other routers on ch10 (spotted your edit) ch11?
-+-No longer a forum member-+-
curtispro
Message 22 of 36
My wifi devices only ever pick up one other network as we live in a very rural area (next doors) so hopefully its a clean channel Smiley Happy
curtispro
Message 23 of 36
Now that I have changed to Ch 11 Apple TV is now working again although the initial loading time was a bit slow, its working fine now streaming HD movies from the mac, just need to sort out the broadband speed and I will be happy again Smiley Happy
DS
Distinguished Guru
Message 24 of 36
OK:)
Other things to consider are
1) BTWifi. Do you use it?
If not, you could opt out of it, via the website, and after an unknown time (it should be 48 hours) the hub will also stop emitting these 2 additional SSID's.
2) Being rural, had anybody added any new equipment local to you?
eg. An electric fence for retaining animals in fields perhaps....
DS
Distinguished Guru
Message 25 of 36
That's sounding good.
For the speed, don't switch the hub off at all, leave it on 24/7;)
curtispro
Message 26 of 36
How do I opt out of that service via the web site as we never use it?
DS
Distinguished Guru
Message 27 of 36
Read this, it's tells you how - http://bt.custhelp.com/app/answers/detail/a_id/12958/c/346,1238,2694
curtispro
Message 28 of 36
Thank you for the link, I will ring them tomorrow as I don't know my email name for that service then switch it off !!!!!
DS
Distinguished Guru
Message 29 of 36
It would be the BT primary email address, possibly in the form of firstname.lastname@btinternet.com and the pasword for that account
If you don't remember, then calling them should allow them to tell you what it is.
If they can't let us know:)
curtispro
Message 30 of 36
Update on the connection speed, still very slow downloading from the net Smiley Frustrated
ADSL line status
Connection information
Line stateConnected
Connection time1 day, 1:25:38
Downstream8,128 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeFast
Noise margin (Down/Up)7.3 dB / 21.0 dB
Line attenuation (Down/Up)21.0 dB / 12.0 dB
Output power (Down/Up)19.8 dBm / 12.2 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)0 / 0
CRC Errors (Down/Up)6 / N/A
HEC Errors (Down/Up)N/A / 3
Error Seconds (Local)3
 and the speedtest
FAQ
Results Image not loaded
1. Best Effort Test:  -provides background information.
 Download  Speed
 1.82 Mbps
0 Mbps2 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 1.82 Mbps
 For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 2 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
Please visit the FAQ if you are unable to understand the test results.
