DS
Distinguished Guru
Message 31 of 36
Re: Admin Password not working, need to check settings
Wait till the hub connection time reaches 3 days, if it's still fixed at 2mbps, the BT forum mods will need to give it a nudge.
-+-No longer a forum member-+-
curtispro
Message 32 of 36
Ok thanks
curtispro
Message 33 of 36
All fixed now thanks guys for your assistance Smiley Happy
1. Best Effort Test:  -provides background information.
 Download  Speed
 5.66 Mbps
0 Mbps7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 5.66 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :8.13 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 7.15 Mbps
If you wish to discuss these results please contact your Broadband Service Provider.
If you are experiencing problems with specific applications, servers or websites please contact your Broadband Service Provider for assistance.
Your test has completed please close this window to exit the performance tester.
john46
Message 34 of 36
Glad all is now ok most times a few days stable connection solves most problems 😉
DS
Distinguished Guru
Message 35 of 36
Glad to hear it:)
georgiagirl
Message 36 of 36
Lucky you to have that. Mine has dropped to 0.2MB. I can't even watch iplayer. BT finally acknowledged after a few months of this and have said there is a fault on the line and are sending an engineer out the second week of January to look at it. Good luck.
