Are there any other routers on ch10 (spotted your edit) ch11?
My wifi devices only ever pick up one other network as we live in a very rural area (next doors) so hopefully its a clean channel
Now that I have changed to Ch 11 Apple TV is now working again although the initial loading time was a bit slow, its working fine now streaming HD movies from the mac, just need to sort out the broadband speed and I will be happy again
@curtispro wrote:My wifi devices only ever pick up one other network as we live in a very rural area (next doors) so hopefully its a clean channel
OK:)
Other things to consider are
1) BTWifi. Do you use it?
If not, you could opt out of it, via the website, and after an unknown time (it should be 48 hours) the hub will also stop emitting these 2 additional SSID's.
2) Being rural, had anybody added any new equipment local to you?
eg. An electric fence for retaining animals in fields perhaps....
@curtispro wrote:Now that I have changed to Ch 11 Apple TV is now working again although the initial loading time was a bit slow, its working fine now streaming HD movies from the mac, just need to sort out the broadband speed and I will be happy again
That's sounding good.
For the speed, don't switch the hub off at all, leave it on 24/7;)
Read this, it's tells you how - http://bt.custhelp.com/app/answers/detail/a_id/12958/c/346,1238,2694
It would be the BT primary email address, possibly in the form of firstname.lastname@btinternet.com and the pasword for that account
If you don't remember, then calling them should allow them to tell you what it is.
If they can't let us know:)
Update on the connection speed, still very slow downloading from the net
ADSL line status
Line state | Connected |
Connection time | 1 day, 1:25:38 |
Downstream | 8,128 Kbps |
Upstream | 448 Kbps |
VPI/VCI | 0/38 |
Type | PPPoA |
Modulation | ITU-T G.992.1 |
Latency type | Fast |
Noise margin (Down/Up) | 7.3 dB / 21.0 dB |
Line attenuation (Down/Up) | 21.0 dB / 12.0 dB |
Output power (Down/Up) | 19.8 dBm / 12.2 dBm |
Loss of Framing (Local) | 0 |
Loss of Signal (Local) | 0 |
Loss of Power (Local) | 0 |
FEC Errors (Down/Up) | 0 / 0 |
CRC Errors (Down/Up) | 6 / N/A |
HEC Errors (Down/Up) | N/A / 3 |
Error Seconds (Local) | 3 |
and the speedtest
