Message 1 of 6
Advanced Digital Voice with Alexa handset sync tone
Hi
Just switched over to Digital Voice with Alexa handset & at irregular intervals (including during the night!) get a 'handset synch' sound which is really irritating !
Can't find how to switch this off - can anyone advise?
Thx
5 REPLIES 5
Message 2 of 6
Re: Advanced Digital Voice with Alexa handset sync tone
after you paired phone with base did you sync alexa?
Message 3 of 6
No - not yet
Message 4 of 6
is it possible for you to sync alexa with existing devices especially your mobile if possible
Message 5 of 6
if you are not going to register alexa then
Deregister Alexa from your hub
If you want to remove the Alexa service completely from your hub. 1 Press Menu when your phone is on the home screen and scroll to Alexa settings, press Select. 2 Scroll down to Deregister Alexa and press Select. 3 Follow the on-screen instructions
Message 6 of 6
Many thanks - will have a ponder and then give it a go!
