Message 1 of 9
Advice on replacing old BT Home Hub
Hoping that some of you more knowledgeable people can help me - I'm looking to replace our very old Home Hub 3A with a newer device. We're having a lot of issues with it randomly blocking all wireless access to the Internet & think it is time to finally upgrade.
I would like to replace it with a non-BT router, but not being an expert in networking set ups would appreciate some advice on what I should be looking at.
We are currently on the BT Halo 1 package, the heaviest usage of the internet is an Xbox One X followed by my works laptop which i use every day via a VPN link. Both of these devices are connected via LAN cable.
Any advice on the best non-BT product to consider would be greatly appreciated.
Thahks
8 REPLIES 8
Message 2 of 9
Re: Advice on replacing old BT Home Hub
With Halo 1, shouldn't BT provide you a Smart Hub or Smart Hub 2?
Message 3 of 9
Halo 1 does not come with a new hub whereas Halo 2 does come with a SH2
Message 4 of 9
If OP calls or chats to BT they will likely send him a new Hub for free, they nearly always do.
Message 5 of 9
Thanks, but i was hoping for some advice on a non-BT product to use ?
Message 6 of 9
@Osirian08
This one is very popular, and works with all BT services. They will not work if you have an ultrafast (G.Fast) connection.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/archer-vr400/v2/
If you only want 2.4GHz then there is a cheaper option.
https://www.tp-link.com/uk/home-networking/dsl-modem-router/td-w9970/
Message 7 of 9
@Keith_Beddoe
Thanks - excuse my ignorance but would this replace just the Hub 3A we currently have, or replace both this & the white openreach modem ?
Message 8 of 9
replaces hub and modem
Message 9 of 9
Modem performance might be better on the Openreach modem depending on the cabinet you're connected to but I would give it a try first and if it's rubbish you can return it and buy a cable router and plug that directly into the Openreach modem.
