Message 1 of 4
Advice please unable to use BT speed checker
Hi
I been to the BT Speedt Test site and it appears not to be working for myself can anyone throw any light on why this might be?
Go to the speed test page - choose FTTC - enter phone number (I have no service number to enter) click go - a pop up box appears which I ok then nothng happens.
Lee
3 REPLIES 3
Distinguished Guru
Message 2 of 4
Re: Advice please unable to use BT speed checker
Hi uklee.
BT speedtester can quite often be problematic, all you can do is make sure you have Java installed , because it needs it, and try again at later intervals.
Please be aware that you must allow at least an hour between tests.
toekneem
(EASBF)
Message 3 of 4
Thanks for the reply
lee
Expert
Message 4 of 4
It would not work for me this morning but I've just tried it again and it's ok now
iechyd da
