Bullitt
Distinguished Expert
Message 11 of 33
Re: Advice please
how does it tie in exactly?
1TonyCurrie
Message 12 of 33
Re: Advice please
Profile drop occurred after that update, although at the same time as the power cuts, just trying to be thorough
Alan63
Expert
Message 13 of 33
Re: Advice please
I would think that's a cocoincidence - I think it would affect the router performance rather than profile.
my profile took a hit due to somee faults . It took 9 weeks to return.
However, now it's slightly higher that it had been. As with you it had been stable for a long time .
as painful as it sounds patience is the key after the faults have been resolved.
1TonyCurrie
Message 14 of 33
Re: Advice please
Ok thanks Alan. The fear of course is that it won't return and as it has been stable for nearly two years, that wouldn't seem right. Thanks to all for replies.
Bullitt
Message 15 of 33
Re: Advice please
thats unfortunate
its impossible to say what role the firmware update or the power cuts play in this issue as you dont have all the information
all you can do is wait and see
1TonyCurrie
Message 16 of 33
Re: Advice please
Thanks Bullitt,
I will just have to hang in for a bit longer.
Bullitt
Message 17 of 33
Re: Advice please
is the reduction actually affecting your use of infinity?
RogerB
Guru
Message 18 of 33
Re: Advice please
If it hasn't returned to normal by the end of February .... pm me. 😉
Bullitt
Message 19 of 33
Re: Advice please
lol 😄
1TonyCurrie
Message 20 of 33
Re: Advice please
@Bullitt, its not what I normally get, so I dont see what your implying?
Roger, I will be outside your house first thing on Friday the 1st feb if not Smiley Sad
