Hammertime13
Message 1 of 5
After Infinity Installation I cant seem to connect to my hub...
As per subject guys, I can access my router with WEP WPS no problem bar one device, a windows xp laptop it say I have a connection and ive reset deleted profile etc no joy, so I tried the FON connection on my router and it works?.. Anyway round this?
4 REPLIES 4
gg30340
Message 2 of 5
Re: After Infinity Installation I cant seem to connect to my hub...
Try setting your Homehub to a fixed channel rather than using smart channel and if your XP uses wireless b/g and not n then change the hub to just b/g rather than b/g/n.
Hammertime13
Message 3 of 5
Id rather keep it on b/g/n as I have other devices connected ok but not xp, and before we had Infinity installed it worked fine
gg30340
Message 4 of 5
I would agree about keeping it on b/g/n but sometimes XP won't connect to the hub when it set that way. Try b/g just to see if it does connect then you will know that is the problem and you could buy a USB wireless n adaptor to use on the XP. You can pick them up for under £10.
imjolly
Message 5 of 5
have you checked that the driver for your wifi card is up to date - check manufacturers website and don't reply on windows update
