Hi there.....
I wonder if anyone can help me with this. I got my Home Hub 5 today to replaced my Home hub 3. Once I installed the home hub 5 all my wireless device has dropped to 10mb!
I don"t know what else can I do coz I tried resetting the home hub 5 and change all the setting on the home hub 5 but still only give me 10mb!
Can anyone please help
Kit Kat
Solved! Go to Solution.
Hi thanks for the repled.
I tried changing the channel to manaul and tried all the channel but no good sight at all. my wireless connection still at 10mb : ( any more advice?
thanks
I have no other advice, other that what is posted on those threads. Its more likely to be a computer/wireless card problem.
Did you try giving the 2.4Ghz and 5Ghz frequencies different SSids as suggested in the links that Keith posted?
Have you checked that you computer's network card drivers are up to date. Use the card manufacturer website not Windows which can be out of date.
