Longway
Message 11 of 33
Re: After years of 63Mbs speed dropped overnight to 50Mbs. Can anything be done?
I'm with BT so guess that it is more than likely congestion. Can you suggest a good guide on unlocking the modem.
licquorice
Message 12 of 33
Have a read here http://www.kitz.co.uk/routers/hg612hacking.htm  Just make sure you follow the instructions carefully and don't be tempted to rush things. Its very straightforward.
Firmware downloadable from https://mega.nz/#F!LdJFDIJL!e_E1twsIg2kTet8mPjrb4w
Longway
Message 13 of 33
My Huawei hg612 is running firmware v100R001C01B028SP10 and won't load any of the unlocked firmwares, any ideas?
licquorice
Message 14 of 33
How far into the process is working? Do you get the update software screen (fig2)? What, if any, error messages are you getting? Which version of the firmware are you trying to load, I suggest the bcm96368MVWG_fs_kernel_HG612V100R001C01B030SP08_webgui  version.
Longway
Message 15 of 33
Right have installed the firmware version you describe with 'webgui' rather than 'unlocked' which has allowed me to pull the stats. All the messing around has allowed an improvement in speed, stats below.
       Downstream    Upstream
Attainable rate (kbit/s)     58324  12758
SNR margin (dB)       15.2   0
Line attenuation (dB) 13.3   6.7
Output power (dBmV)   13.3   6.7
       Statistics            Help
       Path 0 Path 1
       Downstream    Upstream      Downstream    Upstream
Line rate (kbit/s)    59317 12740 0      0
CRC errors    248    127    18     0
FEC errors    0      0      1      0
HEC errors    122    4294967290    32     0
What do you think?
licquorice
Message 16 of 33
You are syncing at 59M but you have a high noise margin which suggests a line fault. Can you repeat the figures when connected to the test socket behind the removable faceplate of the master socket. This will disconnect your internal wiring to ensure the problem is external to you and not being caused by your wiring.
Keith_Beddoe
Message 17 of 33
At 58.3Mbs, you are very close to the 60,8Mbs lower limit. DLM has dropped your speed because of errors on the line.
Are you on Infinity 1 or Infinity 2?
Longway
Message 18 of 33
Apologise to all but I’ll have to do this tomorrow. I’ll post the stats from the test socket as soon as I have them.
Longway
Message 19 of 33
Right I am still trying to get the stats from my 'Test Socket'. I don't have the correct RJ11 to BT phone plug lead yet. My filtered faceplate was installed by BT in 2014 when they install a replacement NTE5 with dedicated sockets for Infinity and phones. Will I need a filter when I do the readings from the test socket?
licquorice
Message 20 of 33
You don't actually need a filter, but it's the simplest way to convert the phone socket to an RJ11.
