Longway
Message 21 of 33
Re: After years of 63Mbs speed dropped overnight to 50Mbs. Can anything be done?
I don't think I've actually still got a filter, might try a phone cord, would that work?
Longway
Message 22 of 33
Right stats.
With BT installed faceplate
       Connection Status
Help
Mode   VDSL2
Traffic type PTM
DSL synchronization status   Up
DSL up time   0
       Line Status
Help
       Downstream    Upstream
Attainable rate (kbit/s)     57880  12474
SNR margin (dB)       15.3   0
Line attenuation (dB) 13.3   6.7
Output power (dBmV)   13.3   6.7
       Statistics
Help
Path 0
Path 1
       Downstream    Upstream      Downstream    Upstream
Line rate (kbit/s)    57973 12437 0      0
CRC errors    248    127    18     0
FEC errors    0      0      1      0
HEC errors    122    4294967290    32     0
Without BT installed faceplate via test socket.
       Connection Status
Help
Mode   VDSL2
Traffic type PTM
DSL up time   0
       Line Status
Help
       Downstream    Upstream
Attainable rate (kbit/s)     39072  8919
SNR margin (dB)       27.5   0
Line attenuation (dB) 13.1   6.6
Output power (dBmV)   13.1   6.6
       Statistics
Help
Path 0
Path 1
Line rate (kbit/s)    34121 8889   0      0
CRC errors    250    127    18     0
FEC errors    0      0      1      0
HEC errors    90     4294967290    32     0
Back to BT installed faceplate.
       Connection Status
Help
Mode   VDSL2
Traffic type PTM
DSL up time   0
       Line Status
Help
       Downstream    Upstream
Attainable rate (kbit/s)     58032  12848
Line attenuation (dB) 13.2   6.7
Output power (dBmV)   13.2   6.7
       Statistics
Help
Path 0
Path 1
Line rate (kbit/s)    58775 12848 0      0
FEC errors    0      0      1      0
Is the lead I'm using for the test knackered?
Webby
Message 23 of 33
Very odd that the test socket yields lower speeds!
Longway
Message 24 of 33
Test socket using a good cable.
       Connection Status
Help
Mode   VDSL2
Traffic type PTM
DSL up time   0
       Line Status
Help
       Downstream    Upstream
Attainable rate (kbit/s)     58108  12433
SNR margin (dB)       15.2   0
Line attenuation (dB) 13.3   6.8
Output power (dBmV)   13.3   6.8
       Statistics
Help
Path 0
Path 1
Line rate (kbit/s)    59120 12437 0      0
FEC errors    0      0      1      0
Does that help?
Longway
Message 25 of 33
Could anyone explain these results for me?
licquorice
Message 26 of 33
You are syncing at 59M but the error and snrm figures are not accurate (a known bug with the gui formware). You need to telnet into the modem and then at the prompt enter
ATP>sh
# xdslcmd info --show
to get the true figures.
Longway
Message 27 of 33
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason: 1
Last initialization procedure status: 0
Max: Upstream rate = 15039 Kbps, Downstream rate = 58760 Kbps
Bearer: 0, Upstream rate = 15017 Kbps, Downstream rate = 54999 Kbps
Bearer: 1, Upstream rate = 0 Kbps, Downstream rate = 0 Kbps
Link Power State: L0
Mode: VDSL2 Annex B
VDSL2 Profile: Profile 17a
TPS-TC: PTM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 7.5 6.1
Attn(dB): 15.2 0.0
Pwr(dBm): 13.3 6.8
VDSL2 framing
Bearer 0
MSGc: -6 -6
B: 227 227
M: 1 1
T: 0 0
R: 12 14
S: 0.1319 0.4829
L: 14562 4009
😧 4 4
I: 240 242
N: 240 242
Q: 4 4
V: 0 0
RxQueue: 132 24
TxQueue: 33 8
G.INP Framing: 18 18
G.INP lookback: 31 8
RRC bits: 24 24
Bearer 1
MSGc: 122 58
B: 0 0
M: 2 2
T: 2 2
R: 16 16
S: 8.0000 16.0000
L: 32 16
😧 1 1
I: 32 32
N: 32 32
Q: 0 0
V: 0 0
RxQueue: 0 0
TxQueue: 0 0
G.INP Framing: 0 0
G.INP lookback: 0 0
RRC bits: 0 0
Counters
Bearer 0
OHF: 0 0
OHFErr: 0 5
RS: 2247668644 2785222
RSCorr: 222841 81245
RSUnCorr: 0 0
Bearer 1
OHF: 22327221 394847
OHFErr: 0 9
RS: 178617276 3760427
RSCorr: 12 753
RSUnCorr: 0 0
Retransmit Counters
rtx_tx: 406499 6619
rtx_c: 1705 50081
rtx_uc: 108626 53545
G.INP Counters
LEFTRS: 22 1636
minEFTR: 54989 15017
errFreeBits: 384170466 729844882
Bearer 0
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 3571919099 0
Data Cells: 534789997 0
Drop Cells: 0
Bit Errors: 0 0
Bearer 1
HEC: 0 0
OCD: 0 0
LCD: 0 0
Total Cells: 0 0
Data Cells: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 21 93
SES: 21 0
UAS: 89 68
AS: 358640
Bearer 0
INP: 51.00 44.00
INPRein: 1.00 0.00
delay: 0 0
PER: 0.00 0.00
OR: 0.01 0.01
AgR: 55120.28 15049.51
Bearer 1
INP: 2.00 4.00
INPRein: 2.00 4.00
delay: 0 0
PER: 16.06 16.06
OR: 63.75 31.87
AgR: 63.75 31.87
Bitswap: 214697/214697 82418/82570
Does that help?
licquorice
Message 28 of 33
DLM now appears to have banded your line at 55M due to the line instability but your max rate is only 58.7M with an SNRM of 7.5dB, so not much room for improvement. You are just below the minimum rate of Range A for your line , but you might have difficulty getting an engineer visit. To be perfectly honest, I can't see that you would notice any difference between 63M and 55M under normal usage. Even if you were to return to your previous speed, I'm not sure the extra cost of Infinity2 is worth it, you might as well opt for Infinity1 and save a bit of money.
If you want to monitor your connection over a period of time to see what is happening in terms of errors etc, have a look  here
Longway
Message 29 of 33
Thank you for your comments. It appears that although for years I had been getting the estimated speed for my line of 63Mbs Openreach will not do anything to return those speeds.
Once VM have replaced the service do I need to inform BT or do I just stop all payments?
pippincp
Message 30 of 33
You should give BT 30 days notice. You may as well as you'll be charged for it anyway.
