bigbilly
Message 1 of 2
AirPlay with Hub 5
I used to watch BT Sport using AirPlay via Apple TV.  Just had the Hub 4 upgraded to a Hub 5, although am waiting for the Infinity connection, but can't get the AirPlay symbol.
Does AirPlay work with the Hub 5 ?
Bill
1 REPLY 1
cooperman
Message 2 of 2
Re: AirPlay with Hub 5
It should work in exactly the same way. Providing both are connected to the same network. Which Apple TV and which device are you streaming from?
