Message 1 of 14
All Set Up!
Well I'm all set up, with the Openreach /r version 2 modem and NETGEAR R7000 along with the MK2 faceplate.
http://tinypic.com/view.php?pic=xg0jue&s=8#.U2Kj3fldWio
I put the username to bthomehub@btbroadband.com
And the password to bt, then updated the routers fireware. I'm using a 1M cat6 ethernet cable from the modem to the router and a 2M cat6 cable from the router to my laptop. I'll post some speed tests in a couple of weeks so it can get used to the Openreach modem from the HH5.
13 REPLIES 13
Expert
Message 2 of 14
Re: All Set Up!
Looking good so far, bud. 🙂
What are your initial impressions of the router?
Message 3 of 14
Re: All Set Up!
Well the set up was good, im getting a faster speed on all wireless devices and even on my laptop which is wired it seems more snappy.
Expert
Message 4 of 14
Re: All Set Up!
That is good news. 🙂
Mind you, with the R7000 having a dual core processor, it does have a but more "omph" than your average router, so it's unlikely to be stressed as easily under heavy loads. 🙂
Message 5 of 14
Re: All Set Up!
The R7000 keeps disconnecting from the internet when know one is using it by the looks from the router logs, if I change the connection mode from idle 5 minutes to ALWAYS ON should I have this issue?
Expert
Message 6 of 14
Re: All Set Up!
Hi mate,
Change the connection mode to Always on - That's what I have with mine and no probs whatsoever, here. 🙂
If you have it set to 5 mins idle then it will DC after that amount of inactivity, which could affect your IP profile, if there are too many connects/disconnects.
See below for a screenie of the settings I use. 🙂
Message 7 of 14
Re: All Set Up!
I bet you take that thing off some sweet ramps, bro.
Sage
Message 8 of 14
Re: All Set Up!
The router disconnecting will not affect the IP Profile as long as the modem maintains connection.
Expert
Message 9 of 14
Re: All Set Up!
No, but sometimes the reconnect forces a resynch.
I know that with my other router, the WNR3500L, if you changed some settings in the web UI, then that would force a reconnect of the PPPoE connection.
Not going to try it now, to prove/disprove my theory, as I have no need to tinker. 😛
Message 10 of 14
Re: All Set Up!
Thank you 🙂
